Question about PfaFF Tiptronic 2030
Phaff Model 7570-thread keeps getting caught in bobbin case. Too expensive to keep fixing. Help!
My thread keeps getting caught in bobbin case and breaks in it. wheel won't move. second time. too expensive to keep getting fixed. Help!
4 Suggested Answers
Zenqi
  • 208 Answers
SOURCE: my phaff wheel seems to be locked up -- what can
There may be a piece of thread logded between the hook and the bobbin case holder. Try turning the handwheel very firmly backward (opposite the sewing direction).
Posted on Jun 17, 2011
SOURCE: pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
Posted on May 03, 2012
  • 1564 Answers
SOURCE: thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Posted on Nov 06, 2012
How do i use jean thread on my juki industrial sewing machine
are you using a denim needle for sewing jeans?
where is the thread getting caught up at?
make sure the bobbin is turned the right direction in the bobbin case
Feb 13, 2013 | Juki Sewing Machines
My phaff wheel seems to be locked up -- what can i do to fix it the needle will not go down to pull the bobbin thread thru ,and it "sticks " when i try to turn the wheel
Jun 16, 2011 | PfaFF Creative 7570
Why does my 9000 keep jaming. I had it fixes and the problem still excist. I find that it balls underneath yet there seemsto be nothing uner in the bobbin case anywhere. I am tires of distroying towels...
What did they fix on the machine? Did they change the bobbin case? Many times the bobbin cases get burrs on them from broken or broken needles. Also the position bracket, (the elbow shaped piece of metal) that keeps the bobbin case from spinning around, has to be positioned correctly. Thread up the machine, put a small piece of cloth under the pressure foot, and turn the handwheel by hand, in the forward direction, and watch the upper thread as it comes around the bobbin case for every stitch, and see that it flows smoothly. If it hangs up any point, the problem might be the bobbin case or the position bracket. Also check the threading. Many times customers assume that the machine is threaded correctly and it's not. Be sure and rethread anyway. And make sure that there is no thread caught between the tension disks.
Apr 30, 2011 | Janome Memory Craft 9000 Computerized...
I need to know how to reset the bottom tension. Mine is loose. I don't have my manual with me - HELP= it is a 7570
A good way to set bobbin tension.
Thread bobbin.
Hold bobbin buy the thread.
You should be able to hold the bobbin up buy the "pig tail" thread and the bobbin should not fall to the ground.
You should be able to give it a good shake and it drop about 2-4 inces.
Are you having looping on the underside of the fabric, if so this will not fix this problem.
If that is the case let me know and ill post a exp for how to fix that.
hope this helps
Mar 30, 2011 | PfaFF Creative 7570
Lower thread keeps jamming even though bobbin case is clean and tension on thread has been adjusted.
Here are some things to try.
* Re-thread your machine
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
Also, before you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope one of these solutions help.
Sep 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Mar 10, 2009 | PfaFF Creative 7570
The thread keeps getting caught in the bobbin area.
Turn the bobbin around in the case so that the bobbin turns in the same direction as the thread is flowing. If you pull the thread in the case and the bobbin turns opposite the flow of the thread then you might have a problem.
Make sure the shuttle is in place, you will have to look at the manual for this. Replace the case and bobbin. Make sure you have a good needle in place.
Aug 10, 2008 | Janome 1600P-DB Mechanical Sewing Machine
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
