Question about Exercise & Fitness
Sole e25 elliptical
Foot pedal keeps slipping off of the rail?
2 Suggested Answers
  • 31 Answers
SOURCE: In elliptical machines, are there different types of foot pedals?
There are two types of foot pedals you should be aware of: articulating and non-articulating pedals. Non-articulating pedals are less desirable due to the fact that the ball of your feet absorb most of the pressure, which will often lead to numbness in your feet. You should look for a machine with articulating pedals. They allow your feet to remain flat, distributing pressure throughout your entire foot as opposed to one part of the foot.
Posted on Aug 02, 2012
Machine starts without operating the foot pedal
I have had the same problem, check that the foot pedal has not slipped back under your sewing cabinet and therefore being pressed down by the cupboard and not your foot. Silly me eh!
Hope this helps
Sep 29, 2014 | Sewing Machines
My Janome Model DC 3018 sewing machine keeps on sewing after I take my foot off the pedal, how do I stop this from happening?
Check that the pedal has not slipped back under your machine cupboard and is being pressed down continually by cupboard frame and not your foot.
Good Luck
Sep 28, 2014 | Sewing Machines
Belt stops when i walk on it
with item going 2mph, stand on foot rails, hold on handles,with one foot try stopping walking belt-look at front roller while doing this-if walking belt slips around frt roller, its the walking belt loose. at each corner there is an adjustment,with proper allen wrench, turn CLOCK WISE one turn EQAULLY on each side!! Then recheck,keep doing this untill it quits slipping-Small moves is best don't crank.
Now on other hand if walking belt Stops with frt roller, its the MTR dr. belt under the hood, to tighten,with 2 9/16th wrenchs, I loosen mtr mount bolt,with one hand apply pressure to mtr, retighten, or have wife apply this pressure with her foot,but don't over tightn-u want to turn belt 1/4-1/2 inch on side. Also check walking lube under walking belt!!
Jan 06, 2010 | Proform 760 CrossTrainer Treadmill
Peugeot 106 1.5D. the clutch was slipping so new clutch fitted 2 weeks ago. It was still slipping so that garage replaced the clutch again. Guess what? It is still slipping. Any idea what is going on?
Yes clutch pedal should start to drive about 1inch off the floor and when driving keep your foot away from the pedal,/ also when new clutch is fitted did they fit a complete clutch assy /and did they surface grind the flywheel as if it was badly worn on the 1st one then the new one wouldent last very long.
as when the clutch starts to drive 1" from the floor clutch is good /when it engages right out its buggered and slips so ask about the f/wheel
Oct 02, 2009 | 1991 Peugeot 405
How do I adjust tension on walking belt
A good way to test your walk belt to see if it is slipping is to stand on side rails with treadmill running about 4mph and while holding onto handrails keep one foot on the side rail and put your one foot on the center of the belt in a slight stomping motion,if the belt is loose you will feel it slip. To adjust a loose belt tighten each screw at back of treadmill 1/2 tun each until the slippage goes away. Be sure not to over tighten belt as this will cause excessive wear.If the belt has shifted to one side and you need to center it, go to the side it has shifted to and turn the screw clockwise 1/4 turn at a time until it centers.
Jul 14, 2009 | Exercise & Fitness
Foot pedal not working
sounda like the rachect teeth inside peddle r worn out probably need to take to shop for repair
Jul 10, 2009 | Kirby Heritage II Vacuum
I just put together a Peg perego Polaris RZR ride on toy and it will go forward, but not reverse. The light showing a full battery goes OFF when I try to put it in reverse. Any ideas? Is there a loose wire...
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
May 06, 2009 | Polaris Ranger RZR Ride on Toy
Exercise & Fitness Logo
85 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
