Question about Kitchen Appliances - Others
Unlock pitco fryer
How to unlock
5 Suggested Answers
  • 11 Answers
SOURCE: Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Posted on Feb 01, 2009
kebah
  • 683 Answers
SOURCE: hi I just baught a used pitco frialator sg18 Js
You can download programming guide at pitco web on www.middleby.com
Posted on May 17, 2011
kebah
  • 683 Answers
SOURCE: my pitco frialator chips fryer diplaying CFG error
CFG error on controller board can be cleared by resetting the controller back to factory setting and by doing this, all program added after the factory setting will be erased so you have to reprogram them again.
Programming guides are downloadable at PITCO site on http://www.middleby.com
Posted on Jun 06, 2011
kebah
  • 683 Answers
SOURCE: pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Our church has a Pitco Frialator Model #14UFMS 110,000 BTU. Do you have a manual?
Hi there.
You can download Pitco Fryer Owner's Manual at
http://www.pitco.com
Regards.
Jun 23, 2011 | Pitco Frialator SG14 Deep Fryer
Just got used Pitco 45 c+ frier. installed, gas is working but cannot ignite pilot let alone locate it. sounds stupid I know but alas....
Visit the Pitco web at www.middleby.com, there are downloadable manuals for Pitco fryers that can help you.
May 23, 2011 | Pitco Frialator 45C Deep Fryer
What are most common problems found with pitco frialator fryers?
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
Feb 09, 2011 | Pitco Frialator SG14 Deep Fryer
How do you clean the Pitco Friatlator deep fryer?
Visit pitco web at www.middleby.com, there are manuals which will help you in cleaning fryers.
Jan 08, 2011 | Pitco Frialator SG14 Deep Fryer
I need to adjust the timer on the right side fryer basket
Hi there.
If your fryer is PITCO, you can download programming manual at http://www.pitco.com
Regards.
Nov 18, 2010 | Pitco Frialator SG14 Deep Fryer
My pitco frialator chips fryer diplaying CFG error
Jul 29, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco fryer
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
I need to know how to lite my deep frier pitco
You can download operations manual for pitco fryers at http://www.middleby.com
May 20, 2010 | Pitco Frialator 35CS Deep Fryer
Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
Jul 12, 2008 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
122 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
