Cuisinart CJK-17BC Cordless Electric Kettle Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What solution will work to clean out the sediment that settles in non-electric teapot? We gave very hard water in our area and the pot if full of white flakes after the water boils.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Mar 30, 2009
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2174814
Points
14133
For that model, instead of the usual vinegar, the solution you need is 1tbsp of cream of tartar for every 2 cups of water. Cream of tartar is normally a spice, so it would more likely be found in the spices section of the grocery store rather than the cleaners section.
How to clean the inside of a henly teapot
detailed instructions are here:
http://www.ehow.com/how_4451477_clean-deposits-from-teapots.html
Sediment build up on element
Copy following link for element resources:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
You can soak element in white vinegar to remove scale, and that will reduce some of the whistling noise.
Cleaning sediment out of tank can restore full efficinecy to electric water heater:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#electric
Another cause of water heater noise are factory-installed heat traps.
http://waterheatertimer.org/New-water-heater-making-noise.html
Add a comment for followup
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Hard water sediment build up
If you clean sediment out of tank, it will restore full efficiency to electric water heater:http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#electric
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Add a comment and attach photo
My water heater makes hoise what can i do to make it quiter
You posted under electric water heater.
1) Gas or electric, the noise is from sediment build-up inside tank.
Once sediment builds up, the only way to solve problem is to clean the tank out.
2) To restore full efficiency to electric water heater and stop the noise, clean the tank:
3) To clean gas water heater is more difficult and less successful:
4) To prevent sediment problem, flush water heater each 6 months before sediment can build up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
5) Other things to know for water heater maintenance.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
I have a Rheem82v52 2 that gurgles 24 hours per day short of Pepto Bismol, what will make it quieter???
The sound is from sediment.
Sound signals need to clean out tank:
Electric water heater can be restored to full efficiency after cleaning:
http://waterheatertimer.org/Water-heater-will-not-drain.html
To find age of Rheem, look at 2nd and 3rd digits on serial number, for example 06 is 2006.
Rheem normally uses 4500Watt bolt-in type element, available at home center or hardware.
Where do you put the filtration system if you want to eliminate all sediment from your hot water tank. Doe's it go before or after the softener and into the hot water tank?
There are two water lines connected to water heater.
One is marked Hot and the other Cold.
The shut off valve is on the Cold line.
To eliminate sand and dirt from entering your water heater, the 'sediment' filter should be installed on Cold line.
Sand and dirt are sometimes called sediment, but this type of sediment is not the same as calcium carbonate sediment that accumulates inside a tank that receives hard water.
When you have hard water, then water heater makes calcium carbonate 'sediment' deposits that accumulate in bottom of tank. A 'sediment' filter will not prevent this problem.
If you have hard water, to prevent calcium carbonate from forming inside tank, you need a water softener.
Water softener will prevent calcium carbonate sediment forming inside tank.
However water softener will shorten life of water heater anode rod.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
2answers
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
2answers
How do I clean the heating elements in my swan tea kettle. it looks like a mineral build up on the elements that comes off when the element is hot and the minerals fall into my tea water
IF THE BUILD UP OF SCALE IS BAD YOU MAY HAVE TO TREAT SEVERAL TIMES TO CLEAN. VINIGER IS A GOOD CHOICE, JUST FILL ABOVE THE COILS AND LET SIT AND DO THIS AS MANY TIMES AS IT TAKES TO CLEAN THE COILS. ANOTHER GOOD PRODUCT IS CALLED- CLR MOST HOME DEPOTS HANDLE THIS PRODUCT IT STANDS FOR C-CALSIUM / L- LIME / R- RUST
THIS IS A LITTLE STRONGER THEN VINIGER BUT DOES THE SAME THING. BOTH WILL TAKE SEVERAL CLEANINGS
2answers
Alessi Tea Pot(not electric)
I do not understand why i must pay all I want to know is how to clean the greae from the Alessi non electric teapot so far I have tried 10 different produsts nothing works. thanks
6helpful
2answers
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Top Cuisinart Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Stan Ford
ADMIN Eric
ADMIN Eric
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
