Where is the water inlet on the miele honeycomb care 460 washing machine
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
  • 1314 Answers
SOURCE: Check Inlet
where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
Posted on May 24, 2008
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
My new Miele Washing Machine (Model no WDA 110) is not taking in water. The programme timer counts down but no water comes in thru powder/conditioner. We have checked the installation carefully and
Hi, Jane.
Is the tap on? (Sorry, I had to ask)
Make sure the filters on the inlet valve(s) aren't blocked.
If all is well with the inlet valves you should hear a faint humming. This is normal.
If it's a new machine it would still be under warranty, so you should get a Miele serviceman to check out the problem.
Good Luck
Cheers
Nomess
Jan 05, 2015 | Miele Washing Machines
I have a miele w864 washing machine that will not fill with water
Does the light "Check Inlet" stay on? If it does, it is likely the water inlet valve solenoids that are inoperative. How old is the washing machine?
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Aug 30, 2014 | Miele Washing Machines
Miele washing machine w 487 check drain and check inlet
Clean out the pump trap. If you are on well water or just have very hard water, your inlet valve may be becoming constricted as well, remove the fill hoses from the back of the machine and shine a bright light into the valve to see if the screens are getting clogged with debris: In this case, follow the instructions the computer is giving you.
Apr 12, 2013 | Miele W487 Front Load Washer
My miele washing machine says water inlet problem
Have you tryed to reset all the dials to zero disconnect power for a couple of minutes and check hose pipe not bend anyware then riconnect power set a wash and start.hope this helps also check pressure of water at inlet.
Feb 01, 2018 | Miele Washing Machines
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
t spins, but doesn't pump
see line clogged and fix it.
It doesn't spin or pump
frozen pulley
It pumps, but the water returns
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
MY WASHING MACHINE WAS OVERFILLED AND I HAVE DRAINED IT BUT IT SAYS "CLOSE THE STOPCOCK" WHAT IS THIS AND HOW DO I DO IT? ITS A MIELE HONEYCOMB WASHING MACHINE PLEASE HELP ME!!!
Hi Kylie from retired Englishman in SW France,
The 'stop-****' is simply another name for the tap of the water feed to the washer- where the washer's water inlet pipe connects ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 28, 2011 | Washing Machines
Need manual for Miele Honeycomb care w3831
You can get the manual on the link below.
http://www.miele.com.au/au/domestic/service/aftersales_operatinginstructions.aspx?product_type=W%203831%20WPS
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 24, 2010 | Washing Machines
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
What do you do if the Miele washing machine's check drain and inlet light is on?
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Feb 15, 2010 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
