Question about GE DBXR463EDWW Electric Dryer
Dbxr463ed0ww Works but don't dry clothes at all.
2 Suggested Answers
canwoodjc
  • 3301 Answers
SOURCE: dryer tumbles but clothes don't dry
check the vents to make sure they are free and clear of any blockages, once thats done, make sure the gas is actually coming on and the burner lights, if thats happening,, then your going to have to check the thermostats , Located in the rear of the machine along the burner vent tube, to check those you need to Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced., be sure and unplug the machine prior to any testing of electrical components
Posted on Jul 09, 2011
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
My dryer turns on filter is clean but clothes do not get dry what is the problem?
90 percent of the time when clothes don't fully dry its due to the vent being clogged or obstructed, check the vent tube and the access vent on the outside of the home.
Jul 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Carrage jam
1) Open door so print heads move to the center
2) Unplug the unit. (Don't turn off, just unplug!)
3) Open back door
4) Look inside the back left side for a small black gear (About the size of a quarter)
5) Spin the gear with a screw driver (I'm pretty sure I spun it clockwise). Spin it and watch the inside of the printer where the print heads park. You should see a tray move out that has four rubber blue rectangles on it on the right side of the unit (this is where the print heads park when the unit is not printing).
6) Keep spinning the gear until the plate moves all the way forward.
7) Grab the plate and try moving it forward more.
8) Put the back on and close the top.
9) Turn the unit back on.
10) Open the top again
11) Unplug the unit again. (Don't turn off, just unplug!)
12) Grab the tray, from step 5, and slide it all the way forward and all the way back multiple times.
13) Make sure that the print heads slide left to right smoothly
14) Remove ink cart's and clean the contacts with bottled water and a q-tip. LET DRY BEFORE REINSTALLING!!!
15) Remove print heads and clean contacts with bottled water and q-tip. LET DRY BEFORE REINSTALLING!!!
16) Clean the inside of the printer with a soft dry cloth, use a slightly damp, with bottled water, lint free cloth (Glasses cleaning cloth works well) and wipe off the rollers in the front and back of the unit. See HP's cruddy support site for details on this step.
17) Hold down #7 (reprimes the printheads with ink) and plug in the unit
Ref - http://www.fixyourownprinter.com/forums/inkjet/22798
May 07, 2011 | HP Officejet 7210 All-In-One InkJet...
When the machine is almost complete with the water draining cycle and starts to spen faster to dry the clothes, a knocking sound is heard then the machine slows down. This continues until the drying cycle...
This may just be an unbalanced load. Does this happen all the time? Is this a front or a topload unit? Try running a load with just a few light items and see if this happens again. If the light load works then you are overloading the machine. Reduce the number of items you put in. Don't put in single potentially heavy items like sweaters, coats or blankets with light items. Good luck.
May 01, 2011 | Maytag Washing Machines
The dryer starts without using the start knob when you open and close the dryer door during a cycle. The dial is also not advancing during the dry cycle and the clothes are taking a long time to dry.
Assuming that you have GE dryer DBXR463ED0WW,
Sounds like there is a couple of problems there:
  1. The start switch is stuck and needs replacement/repair, part number WE4X881
  2. The clothes taking too long to dry may be due to a) clogged dryer vent; b) one or both heater coils burnt out; part numbers: WE11X10007 for restring coils only or WE11M23 for whole heater assembly c) problem with temperature selector switch, part number WE4M407
  3. There might be a problem with timer (WE4M271), but before replacing it I'd suggest taking care of the long dry problem first. In some models, timers are wired that way so the timer advances only when there is heat, so check the schematic.
There should be a schematic diagram inside the control panel, use it to for diagnosing the problems you described.
Good luck,
Vlad
First Choice Appliance
Apr 10, 2010 | GE DBXR463EDWW Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
20 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
