Question about Kitchen Ranges
Ge profile gas range jgsp30 won't light - Kitchen Ranges
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
MNTECH
  • 1543 Answers
SOURCE: GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
SOURCE: Panel of GE profile gas range says 'LOC ON', how
This is the controlled lock out mechanism so that your children cannot play wilth the controls. Press "0" and "9" at the same time and hold them until it says "LOC OFF."
Posted on May 23, 2009
  • 1015 Answers
SOURCE: My GE Profile Gas Range Keeps clicking
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Posted on Sep 17, 2009
mrfixit3667
  • 262 Answers
SOURCE: ge profile gas range. one burner with no clicking and no ignition
Try one to light one of the other burners that work and watch the electrode on the burner that does not light and see if you have spark when you here the clicking nois. (( most gas cooktop spark ignitor all spark at the same time, even if your only trying to light one burner ))
If you do have spark, Then the Ignitor switch is bad.
If you don't have spark then your spark modual is bad.
Posted on Jan 10, 2010
How do I light a pilot light on a GE profile oven?
Modern ovens, especially Profile top-of-the-GE-line don;'t usually have pilot lights. Light with electric element when thermostat is good.
Aug 26, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
My burners won`t click to light
What is the complete model number of the unit?
Dec 15, 2012 | GE Profile 30" Slide-In Gas Range -...
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile gas range: Gas burners don't work
Used toothpick to unclock gas output and worked great.
Jan 22, 2009 | GE Profile JGS968SHSS Gas Kitchen Range
GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Sep 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
