Denon sc avf100 active subwoofer
I can not get it to work.no power light comes on but i have power.
  • IanBart Nov 22, 2007
    I have a similar problem. Simply the scavf100 active subwoofer slow burn fuse keeps blowing. I've disconnected everything, replaced the fuse, only plugged in th emains and switched on. 5 seconds later the fuse blows. I've cleaned the insides, checked the circuits, ensured that the mains isn't spiking. What next?
  • Anonymous Jan 24, 2008
    Same problem - just bought an AVR F100 system and the subwoofer is not working as well as the dvd and minidisc! I have heard that the dvd and minidisc may be sorted with a diode change on the heatsink on the power supply but don't know how to fix the sub.
2 Suggested Answers
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: I have the SB-HW950 subwoofer
Yes, the old Panasonic SC-PT950 did drive the subwoofer by its own amp, such as it was.
http://www.retrevo.com/support/Panasonic-SC-PT950-Home-Theater-Systems-manual/id/2869dj183/t/2/
It's never a good idea to adapt prescribed connectors to bare speaker wire or vice versa.
Speaker Level and Line Level signals are worlds apart and equipment damage may result. Your Denon (model unknown) probably requires a POWERED SUBWOOFER, to which it would provide Line Level LFE from its Pre Out.
Read the manual where it doesn't say to convert a speaker wire to RCA.
Posted on Feb 06, 2011
Denon s101 fault
From the Manual:
PROTECT indicator
This indicator lights red when the system
cable is not properly connected or the
protection circuit in the subwoofer (DSW-
S101) is activated
Nov 09, 2013 | Denon Audio Players & Recorders
Protection light is activated since i installed extra speakers- nothing works now
What do you mean by extra speakers? If you hooked more than one speaker up to one output, you probably blew the amp.
Jul 18, 2013 | Denon S-301
Subwoofer does'nt link with sound bar
  1. The wireless link indicator lights red. Or alternates red and green.
    There is no link between this unit and the active subwoofer.
    Check that this unit is turned on.
    Ensure that the digital transmitter is fully inserted
    into the digital transmitter dock on this unit.
    Turn the active subwoofer off and then back on.
    Alternatively, turn the active subwoofer off, disconnect the AC power supply cord and then reconnect it.
    Consult your dealer if the problem persists.
    Taken from the Panasonic SC-HTB520 Manual
Oct 26, 2012 | Panasonic Audio Players & Recorders
Cant get my sub to work on my denon avr2808 and dont think it ever has it doesnt even work on the test signal
Hello
There are four possibilities that the subwoofer doesn't gives any aoutput. They are:
• Subwoofer's power not turned
on.
•The "Subwoofer" setting at
"Speaker configuration" is set to
"No".
•The subwoofer is not properly
connected.
•The subwoofer's volume is
turned off.
Go to its manual setupscreen, come to speaker setup, speaker confuguration, come towards Sub Woofer, select "Yes" and press OK.
Mar 21, 2011 | Denon AVR 2808Ci Receiver
I have the SB-HW950 subwoofer and teh SC-PT950 speakers and I just purchased a Denon Receiver to replace my DVD/ receiver player. So now I have SC-PT950 speakers playing through the Denon but for some...
Feb 06, 2011 | Panasonic Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
Just bought a denon, and wharfdale 9.1 speakers with no rca cables, what rca cables do i need?
What model speakers?
Didn't these things come with manuals?
Speaker connections from the Denon are typically through speaker cables (glorified lamp cord).
The Denon is not capable of driving the sub directly. The powered (?) subwoofer in your setup would presumably require an RCA cable (whatever length reaches) to feed its amplifier a bass signal from the Denon's Subwoofer Out.
Mar 23, 2010 | Denon AVR-2105 Receiver
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
347 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
