Medion akoya p2004
When I use my pc (medion akoya p2004) as a screen for my ps3 i cant control the volume???
mewms_14904
  • 1027 Answers
SOURCE: Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
Posted on Mar 19, 2008
ssebata paul
  • 159 Answers
SOURCE: My Medion Akoya will not boot
reinstall the operating system
Posted on May 23, 2009
SOURCE: i would like to restore my medion akoya to the
TRY THE F3 FUNCTION UPON START UP-I HAVE A MEDION AKOYA P6612, AND IT WORKED ON THAT
Posted on Nov 03, 2009
clb199
  • 164 Answers
SOURCE: I have medion akoya s5610 laptop. Power light
  1. Believe it or not, the number one reason why a computer won't turn on is because it wasn't turned on!
    Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button on your computer:
    • Power button/switch on the front of the computer
    • Power switch on the back of the computer
    • Power switch on the power strip, surge protector, or UPS (if you have one)
  2. Verify that the power supply voltage switch is set correctly. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on at all.
  3. Check for disconnected computer power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
  4. Perform a "lamp test" to verify power is being provided from the wall. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
    Note: If you have a multimeter or another electrical testing device you are welcome to use that to test your wall outlet (and power strip, surge protector, etc.). The lamp test is useful if you don't have an electrical testing device.
  5. Test your power supply. At this point in your troubleshooting, it's very likely that the power supply unit in your computer is no longer working and should be replaced. You should however test it just to be sure. There's no reason to replace a working piece of hardware when testing it is fairly easy.
    Replace your power supply if it fails your testing.
    Important: In the huge majority of cases when a computer isn't receiving power, a nonworking power supply is to blame. I bring this up again to help stress that this troubleshooting step should not be skipped. The next few causes to consider aren't very common.
  6. Test the power button on the front of your computer's case. It's not a very common point of failure but your computer might not be receiving power because the power button on the front of your PC is damaged and is not actually turning your computer on.
    Replace the power button if it fails your testing.
  7. Replace your motherboard. If you're confident that your wall power, power supply, and power button are working, it's likely that there is a problem with your PC's motherboard and it should be replaced.
Posted on Nov 27, 2009
  • 3940 Answers
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Posted on Jan 11, 2010
Testimonial: " many thanks will get it looked at"
My sound keeps buzzing and going glithcy on my medion akoya E6239. How do I fix this?
Goto Medion website-support and download latest drivers. Install these.
Dec 26, 2014 | Medion Computers & Internet
No sound from built in speakers
It could be that you need up to date sound drivers. You can download from
http://johnsondrivers.com/download-driver/MEDION/AKOYA-S4213-MD-98064
If that fails, take it back to your retailer or get in touch with Medion
Mar 05, 2014 | Medion Computers & Internet
Akoya medion split screen
check the screen cable first. as it does not always happen. tilt the screen front and back to see it at some angles the split stop then you can confidently say it's the cable
Jan 03, 2013 | Medion Computers & Internet
My medion akoya laptop won't load past intel screen
This is a hard drive issue or windows have corrupt files, if you have the installation disc try and reload the operational system, if no change! have the hardware checked out at a computer repair store.
Apr 08, 2012 | Medion Computers & Internet
I have a mini laptop e1212 medion akoya product with a webcam but i cannot use it ..may be it is installation problem i do not know.i will be very greatful if this problem can be solved.
It will be good to have the PC reset to an earlier set restore date. Now the OS will be reset and if there are errors it will be corrected.
Also please check to see if the drivers are OK in the device manager . If this wont solve you will need to reinstall the OS and the drivers of the PC.
Mar 21, 2011 | Medion AKOYA MINI E1212 COMPATIBLE LAPTOP...
The inverter on my Medion Akoya E5312 has broke, where can I buy a new one?
I don't know where are you located but this company could be a great start where you can find your inverter:
http://www.laptop-lcd-screen.co.uk/laptopparts/MEDION-AKOYA-E5312-15.4-LAPTOP-SCREEN_7500.asp
Mar 03, 2011 | Computers & Internet
Setting up dialup modem for Medion Akoya E7330D
yes
go to control panel -> phone and modem options -> modem ->add ..............Thanks
Oct 04, 2009 | Computers & Internet
May 02, 2009 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
