Question about Samsung UN32EH5300FXZA 32 in. HDTV
Tv picture tube 32 inch price in chennai
Picture 50% line screen
5 Suggested Answers
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
GadgetRaja
  • 150 Answers
SOURCE: 50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... rajanetworking@gmail.com
Posted on Sep 02, 2009
  • 6 Answers
SOURCE: i have a 50 inch samsung plasma tv that i think
Upper/Lower Y Buffer defect
- Replace the corresponding upper/lower
buffers (E, F)
Posted on Feb 10, 2010
Testimonial: "many thanks really appreciate your input. how much should i expect to pay for the repair. cheers "
  • 302 Answers
SOURCE: i have a samsung LN_T4061F and it has vertical colored lines on the right side of screen on all channels. lines are about 1 inch from side of screen and are about 1/5 inches side.
Hi there are a couple of hings that could be bad with your tv. Your screen or your t-con board would be the most obvious. Screens are expensive to replace so I would try replacding the t-con board. The t-con is the board thattransfers your signal to the lcd screen. It is usually located on the top center of the tv. You would need to open up your tv and get the part number fro the board.
You can get get parts for this tv at www.interliquidparts.com
Posted on Nov 26, 2011
Television
if you are using a cable box, tried to reset. then tried to unplug any connectors that has been hooked to the component input of your tv.
Oct 26, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
Hello i bought a philips big screen tv from a second hand store anyway the screen has a green tint to it,i was wondering if it could be the picture tube? If so around what would the price of one be? The tv...
Never buy a used plasma,Period,,,,because these tv,s are made to work right for only so many hours and than start there troubles. Always look at any used tv back and get the manufacture date,this way you can see how old it is,,,,,,,,,Alot of flat screens called LCD dont last long eithermall I can say is check with consumer guide before you buy even a New one. Cany say whats wrong with your used one but now you know better on how to buy one.
Mar 13, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Screen turns green The picture and sound are fine when I turn on the tv. After about thirty seconds the screen turns green and then turns off and the power light blinks.
Sad to say, but that's one of the ways a picture tube can behave when it's gone bad. After it warms up, one of the wire elements in the neck of tube sags and touches something it shouldn't. As a result you're seeing the green screen, and then the set shuts down for safety because of voltage feeding back. The only way to repair the set would be with a new tube, and that's completely uneconomical. You can buy a new 32-inch LCD set now for less than the price of a new tube, not including the labor to install the replacement and get the color alignment (convergence) set up.
Mar 08, 2011 | JVC AV-32F704 32" TV
The color on my 32 inch sansui flat screen is xray like dark.
Hello
Either your Sansui TVs screen voltage has gone very low, or its brightness control section inside its chroma IC has damaged. To make sure which is faulty, you have to open your tv. There is an LOT [Line Output Transformer], which can be locted on the main board of your TV, from which three wires will go to the picture tube, out of which one will be connected directly to the picture tubes upper side, look like as it is sucked by a rubber ******. Usually this component is balck in colour and will have two adjustment controls integrated with it, marked as "screen and focus". After switch on your TV, just adjust the "Screen" control preset a little clockwise to see whether there is any advance in the bright ness of the picture. If the focus voltage is less or its wire connection to the picture tube base socket gets corroid; this type of fault may occur also. Check that also. If these does not help you, the chroma IC has damaged, and should be replaced with same type and number. OK.
Feb 24, 2011 | Sansui 32" TV
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
Horiznal line across screen
The picture tube itself is not longer being manufactured and the replacement might exceed the price of a new TV.
The vertical line you see on the picture tube is not a failure with the picture tube but a different part inside the circuitry.
Dec 07, 2008 | Toshiba CN35F95 35" TV
32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
May 27, 2008 | RCA 32F531T 32" TV
JVC 32 INCH MODEL AV-32S585
is the bright line on the midle of the tv , if it's what u ia vertical problem also sometimes is the flyback , tv needs service ,
Apr 30, 2008 | Televison & Video
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
Tosh widescreen ghosting vertical lines
there is no convergence adjust in a 32" tv. Convergence is done when there is more than 1 picture tube, ie; 50" projection sets have 3 tubes so convergence can go out. post the model number of your set and we can help more, BMW Rider
Dec 14, 2007 | Televison & Video
Samsung UN32EH5300FXZA 32 in. HDTV Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
