Question about Bernina Sewing Machines
What is the difference between a bernina record 930 and just a bernina 930
  • Bernina Master
  • 10,284 Answers
At the present time, Bernina 930 Record and Bernina 930 are the same machine. Although, technically the name is Bernina 930 Record, referring to the mostly mechanical sewing machine produced in the 1980's. They are very coveted machines and one of the more popular models.
However, Bernina has, in the past few years, begun producing computerized machines and labeling them with the same numbers of older mechanical machines (makes things very confusing), ie Bernina 830 Record vs Bernina 830 computerized model. At this point in time, Bernina has not yet produced a computerized 930.
Posted on Apr 26, 2015
4 Suggested Answers
  • 19 Answers
SOURCE: Bernina 930 where to put oil
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops.
Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
  • 166 Answers
SOURCE: Bernina 930 foot control cord
Not easily - the plug is molded-on so it's best to get a complete new cord - they're still available.
Posted on Mar 12, 2012
  • 68 Answers
SOURCE: Bernina Record 930 Electronic, seldom use, like
This more likely has something to do with the needle stop device
Posted on Mar 09, 2013
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Wheel on right side that controls the needle up and down is very tight...
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
Need Bernina Record 930 repair manual
There are a whole number of YouTube repair videos on Bernina "how-to" repairs
Bernina Sewing Machine Disassembly
When you launch the above mentioned link, you will see other types of repair videos that may be of help to you in the right pane.
I was unable to locate a repair manual, but for what it's worth, I was able to locate a user's manual
Bernina Record 930 Electronic Manual
Feb 22, 2017 | Bernina Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Can I sew a Blanket stitch with my Bernina 930 Record machine?
Once upon a time, a blanket stitch used to be a long wide zigzag stitch. If you are referring to an electronic stitch version that would look like the inverse of a blind-hem stitch, then no, this is not possible on the 930 record machine.
What is nowadays called a blanket stitch used for quilting applications requires the machine to stop feeding during the stitching cycle to allow for the single stitch to the left and then back again. An electronic step motor machine, common to all newer Bernina machines can do this and or similar functions. That being said, don't be thinking about getting rid of your 930. Better to get one of the newer units for occasional blanket stitching and keep the Swiss made 930. The Bernina 930 is a lifetime machine. Computers machines are not lifetime class machines by virtue of being computers. Electronics are short lived.
SewTechnical Home
Jun 17, 2014 | Bernina Sewing Machines
Blanket stitch for the 930 bernina
The Bernina 930 Record does not have a blanket stitch. It has a few decorative stitches that are similar, but not exact.
Mar 16, 2012 | Bernina Sewing Machines
Needle wont move on my bernina 930
Could very well be the basting stitch mechanism. This is a very common issue on the Bernina 930 Records. The basting stitch should be run frequently (once a month). If it locks up, the machine has to be taken to a technician.
Feb 16, 2012 | Sewing Machines
Sewing Machines Logo
413 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
