Fortecstar fs400v2 reciever showing eep1 on display
Sony reciever shows protect on display
May be bad connections on the preamp ic's. Otherwise there is a short in the amp that needs to be repaired.
Jan 02, 2013 | Sony Str-d350z, Av Am/fm Reciever, Home...
Dialled calls,missed calls and recieved calls
hi,
in my phone dialed, received and missed call data are not saved. all data vanished and it shows empty always
Jul 09, 2010 | Samsung Cell Phones
My dsr922 will not boot up properly
clear the receiver to factory setting and start over.
Jan 15, 2009 | Arris DSR922
Need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
Dec 25, 2008 | Sony STR-DG520 Receiver
Up grading Fortec Star (Lifetime II) reciever.
my fortec star reciever is not up grading through (Action HBS link box) to open Showtime program
Apr 25, 2008 | Fortec Star Lifetime ULTRA
Fortec star lifetime ultra
Press "OK" on your remote control, now continue with the antenna settings and perform a new scan.
Good Luck.
Feb 02, 2008 | Fortec Star Lifetime ULTRA
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
29 people viewed this question
 Grubhead
Grubhead
