Carrier start thermistor
38se004300
How to solve E4 error code shows at my A/C
The E-4 is either a discharge thermistor or the Pc board, in my experiences has always been the thermistor.
Hope this helps.
Michael
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 28, 2014 | Carrier Heating & Cooling
Malfunction display saying outdoor sensors. Everything checked out fine with the unit and the display board, so the problem is with the communication between them. Any answers?
Usually an outdoor sensor is a thermistor. You need to check the resistance range on the thermistor to see if its withing specs. If it isn't you will get an outdoor sensor error.
In all likely hood the sensor needs to be replaced.
Oct 05, 2014 | Carrier Heating & Cooling
What is the E4 alarm on carrier ac
If it is window type AC the possible problem is thermistor or PCB itself.Kindly check the pics below if the control panel is the same.
Sep 06, 2011 | Carrier 38CKC042 Air Conditioner
OD ERROR
Fatal error code 0D: No head error
A check of the print head thermistor circuit during power-on initialization determined that the PRINT HEAD is not installed. This error is caused by the following:
? The Print Head is not installed.
? The Print Head built-in thermistor element has failed.
? The Carrier Cable is disconnected or damaged.
? The Print Head temperature detection circuit has failed
Jun 07, 2011 | Epson DFX-9000 Matrix Printer
Error code 112. what is the problem?
Hi Pramesh
Not a normal carrier code, there may be a point between the 1.12 or 11.2
1. xx normally compressor 1 fault
2. 1.12 is compressor 1 condenser entering water thermistor fault, the unit will continue to run
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/30g,h-3t.pdf
If you follow this link you should be able to download the manual for this unit and that may help you further
Regards
Gordon
Apr 17, 2011 | Carrier 30HXC096 Indoor Water-Cooled Screw...
Error 16 turn printer off
Hi -
The error codes 16 means that you need to check the print head thermistor circuit during power-on. Printer initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician or your local service provider
Hope this helps,
Good Luck!
Feb 28, 2011 | Epson DFX-9000 Matrix Printer
DFX 9000, just over 1 yr old, Skipping lines withing the print. Then generate error OD
From our FixYa forumn:
The error codes OD means that a check of the print head thermistor circuit during power-on initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician.
http://www.fixya.com/support/t1051554-epson_dfx_9000_error_code_od_ob
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Epson DFX-9000 Matrix Printer
Blinking indicate at indoor unit
reset your unit by disconnecting the power supply for 10sec. and "on " the unit for testing. if error persist you need to replace your thermistor.
Jan 25, 2009 | Carrier 38CKC042 Air Conditioner
Not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Dec 30, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
