Question about Sewing Machines
My Pfaff synchromatic 1229 is stuck sewing backwards
The lever for forward stitch and back stitch is in the horizontal position which is where it is supposed to stitch forward but it is consistently stitching backwards and wont change to forward no matter what position it is in.
kimbo322
  • 10 Answers
SOURCE: Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Posted on May 04, 2008
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 10 Answers
SOURCE: PFAFF 362 Sewing Machine: The shift
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Posted on Jan 08, 2010
  • 68 Answers
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Posted on Feb 25, 2010
  • 166 Answers
SOURCE: Why does my machine now only stitches backward, and no decorative stitches
You dont state what model of machine this is, however I have come across this problem mainly on Elna computerized machines and it has been exclusively due to failure of the driver chips on the processor board that control the stitch length stepper motor. You can confirm this by checking whether you can vary the stitch length as well as just the forward/reverse. Same applies to Bernina models, but I dont know about others. Either way, you need to have it checked by your tech.
Posted on Aug 28, 2012
Blanket stitch on Pfaff 1171
You need to check your owner's manual. Most machines of similar age do not have the blanket stitch.
Looking at Pfaff 1229 sewing discussion topic PatternReview com
(see comment)
Pfaff 1171 Tiptronic Sewing Machine
Aug 09, 2017 | PfaFF Sewing Machines
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Pfaff 1229 feeder dog too low
if you have a manual to see where the feed dog lever is, to see if it's
in the up position, if not have the machine checked to see if the
feed dogs need to be adjusted
Jun 12, 2012 | PfaFF Sewing Machines
Feb 24, 2010 | Sewing Machines
Where do you oil the PFAFF Synchrotronic 1229?
1229 or majority of PFAFF's needs to be oiled in the bobbin cage and nowhere else.If you start oling the gears lint will build up and slow your machine down. So only apply a few drops where where the bobbin is attached to.
Feb 10, 2010 | PfaFF Sewing Machines
Only sews backwards
You probably have it in the buttonhole stitch.
Mar 23, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Pfaff 1222 and pfaff 1229
Have a certified repairman look at the power board in the machine. The power supply circuits are broken on the board itself. Can be repaired with wire and solder. How do I know? Just fixed my wifes 1229 that had the same problem.
P.S. New boards are NOT available from PFAFF or anyone else
Sep 26, 2008 | PfaFF Tiptronic 2030
Best,
Kim
Mar 18, 2008 | PfaFF Creative 7570
Sewing Machines Logo
59 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
