Question about Refrigerators
Samsung RT26HC my refrigerator not cooling, but only refrigerator air run . so i am check overload, start realy this ok . so what's problem . plz reply ndas
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
SOURCE: small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Posted on May 06, 2009
mgprice
  • 744 Answers
SOURCE: FREEZER RUNNING OK REFRIGERATOR NOT COOLING
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 14, 2009
  • 2468 Answers
SOURCE: compressor kicks off on overload/relay. Even after
are you sure the condenser fan is running correctly to move air over the condenser and is the condenser free of dust and dirt so it can cool properly from air movement from the fan
Posted on Mar 23, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag model # mbf2254hew bottom freezer refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Tip
Checking out a air conditioner compressor and compressor problems FIRST...
FIRST DISCONNECT ALL ELECTRICAL POWER
Ohm the windings
C to R = example 1.2
C to S = example 3.2
R to S = example 4.4 total of C to R and C to S or very close.
Then ohm each terminal to ground you shouldn't get any reading
If the compressor is hot or you tried to start it, the ohms will be close but not exact.
No reading from C to R or C to S open winding or thermal overload.
Let compressor completely cool down then ohm the C to R and C to S again
If it’s an open overload, you will get an ohm reading after it cools down and the overload closes,
you may just need to add refrigerant.
No reading from R to S and C to S open start winding.
In case of any open windings the compressor will have to be replaced.
If the compressor is getting the proper voltage and won’t start, it could be locked up.
You need an Ammeter to check this to see if it’s drawing locked rotor amps (60 amps or above)
You also need to check the run and start capacitor.
A bad run or start capacitor, the compressor won’t run, it will just hum.
If the compressor will run, but quits after a while and all of the above checks out OK.
It could be drawing high amps ( you will need an ammeter to check this out). Dirty condenser or condenser motor not running, overcharge of refrigerant, shunted windings, bad bearings in compressor.
The compressor gets hot and Suction or big line coming in to outdoor unit is warm or slightly cool, you are low on charge or metering device bad or stopped up.
If compressor runs for a while and quits and the suction line is frozen, cold or cool, then the filter, evaporator or condenser coils are dirty or plugged up, blower or fan motor not running and unit going off on high or low pressure switches.
on Dec 29, 2009 | Heating & Cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
My A C conpressor is cycleing realy fast, every few min. would it be the conpressor capacitor ?
No. It is "short cycling" probrably because it is low on refrigerant which means there is a leak somewhere. The refrigerant cools your compressor windings. If it is low it cannot cool the windings and it will stop the compressor due to a temp overload. As soon as the compressor cools back down it closes the bi-metal switch and allows the compressor to start again. The cycle will repeat itself until the compressor finally quits. Hope this helps.
Please rate my response on FixYa.com
Aug 03, 2011 | Dometic Rooftop RV Air Conditioner
Compressor goes off on overload. Replaced the overload relay,the ref. came down to temp. and would not restart. Installed a new start kit with overload and capacitor. Same results,came down in temp.but...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 23, 2011 | Kenmore 73503 Stainless Steel Bottom...
All electrical, relays and overloads check OK. Compressor is running but fridge is not cooling. Coil underneath is not cool. No indication of fluid leak. What do I check next.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 30, 2010 | Whirlpool Refrigerators
Compressor kicks off on overload/relay. Even after replaceing overload/relay and cap. It will run ok for a week if you let it cool down.
This is often found in small compressors when they heat up too much or too often. check to be sure the condenser coil is clear and has good airflow. If so and it still trips on overload then the compressor is bad. Hope this helps. Good luck.
Mar 23, 2010 | Amana ARB8057CSR Bottom Freezer...
Refrigerator fan running not cooling
Good day,
That is the compressor not running. Could be a bad compressor, or one of it's starting components.
You can remove the start components from the compressor, by removing the cover, and pulling them off the compressor pins.
Any decent sized appliance parts house will test the components, usually made up of the overload protector, start relay, and on some models a start/run capacitor.
If any parts check bad, replace them, if they all check O.K. then you will need the services of a trained service tech.
Feb 20, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
25 year old Whirlpool side by side fridge not cooling. Thermostat OK, both fans running, relay OK, overload protector stays closed 10 seconds or so then kicks out for a minute or so then closes again and...
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
May 01, 2009 | Whirlpool ES5FHAXS Side by Side...
The starter/overload and overload protector unit melted but the capacitor looks ok. Does this mean the compressor is shot or just got overloaded?
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
Nov 12, 2008 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
