Question about Toys
Graco swing #1783224
How do i remove the legs to attach them to a new motor.
5 Suggested Answers
SOURCE: assembling baby swing
I have a baby swing in pieces. Could you show me a picture of how it is put together please
Posted on Jun 17, 2010
SOURCE: Graco swing will not swing
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Posted on Oct 20, 2010
  • 5 Answers
SOURCE: trying to find instructions and
You should be able to contact the company and get replacement parts.
Posted on Oct 21, 2010
  • 1833 Answers
SOURCE: the swing was put together
Testing
Posted on Apr 06, 2011
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
There a bar that came off the swing that I have. Just using for the first time it was given to me by some one so it does not have instructions. So can u pleaseeeeeeee help me and tell me where the bar is...
Most of the time if you go to Graco's website they have manuals for these type of items. I had to do it for my new Fisherprice swing. If you can not find it there call them and they will send you one. I had to do that before too.
Jul 08, 2011 | Graco Winnie the Pooh Swyngomatic Infant...
I have just purchaced a graco bounce n swing. ive inserted leg tube into wrong side n cant get it out. what should i do?
There is a plastic casing around where the leg snaps in. Lift this section with a screwdriver being careful not to break it. With it lifted, push down on the end of the leg that is incorrectly inserted and push down. I had the sane exact issue and this is how I figured it out. Good luck!
Mar 29, 2011 | Graco Swing N Bounce, Inman Park
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Oct 19, 2010 | Graco Toys
Graco swing not working, I'm trying to open the motor box, but can't get the last screw out, which is behind the swinging attachement.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Nov 15, 2009 | Graco Baby Gear
Graco swing has very limited range of motion. It still "works", but something inside is damaged or fell off. I have taken it apart to see the parts in motion, and it all looks like it is doing...
We bought a used swing (lovein hug). It was in super condition but we noticed the same thing where it would hardly swing. My husband, who seems to analyze things that don't work, took it apart to see why so much slop was in there. He couldn't find anything obvious why it was doing that, so he took a piece of small cardboard (off an oatmeal box) and wrapped it around to make it fit on both sides and wrapped it with black electrical tape and stuck it back in. It's hardly noticable. We also changed the legs around to make sure the legs make the swing lay back.
Hope this helps!
Oct 20, 2008 | Graco Simplicity Rock n Roll 330 Crib
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
