SOURCE: Amana top loading washer top agitating
empty washer move agitator clockwise and revese couter clockwise if you don't feel any click at all you had bad part call dog agitator it in side the agitator.good luck
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
SOURCE: Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
SOURCE: I HAVE AMANA WASHER MD #LW9203W/L2 , FILL WATER ,
check the lid switch if it is bad it will cause the unit not to operate after filling with water...
hope this helps you out good luck
