Question about Whirlpool Calypso GVW9959K Top Load Washer
C1 error I am getting a c1 error on my machine. it will wash but not spin out the water. can you give me some ideas on what the problem is and what parts may need to be replaced. thanks
    President:
  • 878 Answers
Dr, C1 occures when there is a spike of 25 amps or more on the motor windings. This can be caused by overloading, the drive motor itself or the motor controller. You need to do some tests on the motor windings to see if they are in spec. Easiest way is on the board. Using a putty knife, slide it under each end of the consol and press on the spring. Push up on the consol while pushing in. The consol will lift up. The motor contoller board is on the left. The P6 harness is in the center. With the washer unplugged, unplug the P6 harness. Measurements on the harness should read: From the red wire to white/black=3.1 ohms. From yellow to white/black=2.8 ohms. From red to yellow=5.9 ohms. Or if you want to read them direct at the motor. Remove the harness and at the motor, red to white=3.1, yellow to white=2.8, red to yellow=5.9. If you have a reading that is much higher than the posted a problem exists in the motor windings. If they check ok, then the problem is in the motor controller. It's up to you but I sure wouldn't put any money in this machine. It has been my experience that there is just too many failures on this model. Catriver.
Posted on Aug 27, 2007
SOURCE:
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Have a 7.5 Kg Fuzzy Logic top Loader that does not spin
Hello.. DE Error means door error but if wash cycle is working properly means you need to change your drain motor.
Feb 13, 2018 | LG Washing Machines
I have a Frigidaire Affinity front load washer Model ATF7000ES0 and am getting error code E38
Hi Scott Brown: Typically an error code E38 could mean a few things:
· First see if the air trap is clogged. If it is, that is probably the most likely issue.
· If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
· To make sure it is not a false error code, reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds.
If the error code continues to display, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Apr 15, 2013 | Frigidaire Affinity ATF7000E Front Load...
My washing machine comes up with error code 4e i have changed the solenoid valve and cleared any possible blockage water is flowing in to the machine but still getting the same error code if i chose the...
Your machine has a fault with the water level contoller switch - pressure switch that activates when water reaches the level set . So check the water level controller and test. If not the fault can be with the program controller unit.
Please check this link for parts identification.
http://www.espares.co.uk/advice/washing-machines/a/7/40/identifying-washing-machine-parts.html
Sep 17, 2011 | Samsung Washing Machines
Placing the drain hose from the lg front load washer it leaks excess water and it spin but do not get the water out of clothes on spin cycle and I notice the drain hose is flat like a tire
Flat like a tire? That is an indication of a vacuum situation.
The first thing I would do is make sure that the pump is getting an activation voltage when the washing machine goes into spin. If it doesn't it is either your controller board or your timer circuit. If you are getting a signal at the pump then you will need to replace the pump.
Since I don't have your model number, I can't look up those parts to give you an idea of what the parts will run.
Jun 05, 2011 | Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
I have a c1 error on an AEG oko favorite 50700 What dies this error mean
I don't understand why replies talk about the C2 and C3 errors... The problem is C1! I have the C1 error. I start a programme, it does the draining cycle to check empty then starts filling. MI can hear water entering but it sounds slow at a low flow rate. If I leave it going, eventually the programme stops and the error is displayed: C1 Opening and closing the door allows the programme to continue. I get the error after the various stages of the programme, when it is filling for the next wash or rinse. So it's 4 or 5 times I think during the programme. Now, if I help the filling... When the appliance is filling, I open the door, and poor in a kettle or two of water, then the error does not happen (the fill is within the time expected by the appliance?) So I am thinking one of two things is wrong: 1) I have a flow rate problem BEFORE the water connection to the appliance. E.g. It is blocked somehow. 2) There is something which opens/closes the "tap" within the machine which is causing the flow rate to be low and it does not fill quickly due to that. No idea which of these two, but I did disconnect the hose of the supply and check that water flows quickly from it into a bucket, so I am thinking there is something inside the machine which "opens the tap" and it's not doing a good job of it. Anyone got a clue?
Dec 18, 2008 | AEG 24 in. Favorit 50730W Free-standing...
Whirlpool Washing Machine shows error code C1
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
706 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
