Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower stalls motor stalls when PTo is on have new pto new pulleys belts and replaced coil
    Sergeant:
  • 416 Answers
Make sure belts arent around the guides to keep the belts on.
does it smoke or make any other noise
why did yu change all the parts
Posted on Oct 17, 2013
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
  • 95 Answers
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
mowerman1857
  • 389 Answers
SOURCE: PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
Posted on Sep 21, 2009
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
John Deere 265 replaced pto switch on dash pto drive belt and mower deck belt still pto does not engage...also randomly blows 20 amp fuse from time to time when pto would engage previously...checked...
The electrical is part of the PTO clutch assembly. It should only draw 5-7 amps. Ohm reading is somewhere between 1.7 to 2.5 ohms.
These coils do short from anywhere from a partial short to completely.
Jul 26, 2014 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    How do you put the drive belt for the hydrostatic drive on?
    You'll be working underneath the mower, so it is helpful to raise the mower chassis up -- at least in back. Use your automobile jack, then put jackstands underneath the chassis to do this. Take off the deck drive belt first by releasing the idler spring(s). Unbolt and remove the "anchor" that keeps the PTO clutch from rotating. Disconnect the electrical wires leading to the PTO. Release the tension on the idler for the hydrostatic drive belt. Now you can thread the new hydrostatic belt over the engine pulley and around both wheel motor pulleys. The idler pulley presses it inward to provide tension. Refasten the idler spring - a pair of channellock pliers works well to hold and pull the spring. Now reinstall the wires and the PTO anchor, then the mower deck belt. Good luck! Please rate my answer if helpful, thanks!
    Jul 02, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
    Replaced belt for mower thought i put it all back correctly blades engage when key is turned engage lever to off what did i do wrong
    If you look at the motor pulley area, there should be two different pulleys with a PTO clutch between them. The PTO clutch has wires going to it, because it is operated electrically by the blade engage switch.
    It sounds like you could have accidentally put the mower deck belt onto the main drive pulley (which turns all the time) rather than the pulley that is farther out from the engine, which only turns when the engage the blade switch. If so, just loosen the mower belt and move it to the right pulley.
    Jun 09, 2010 | Garden
    Broken belt
    This is actually pretty simple:
    Remove Pto guard on mower deck
    Stand mower up on back stands
    Pull the friction disc away from the drive disc
    slip new belt in between the friction disc and drive disc pushing all the way through
    release friction disc allowing to come back in contact with drive disc
    loop belt around engine pulley
    let mower back down
    route belt around mower pulley
    loosen guides on idler pulley
    route belt through idler pulley
    with engine off move pto lever to tighten mower belt
    adjust guides on idler pulley allowing 1/8" from belt
    tighten bolt on idler pulley
    release pto tension
    install mower pto guard
    and you should be ready to mow
    Aug 14, 2009 | Garden
    Engine stalls when electric PTO clutch is engaged
    check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
    you should be able to turn it fairly free less some clutch drag
    Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
    Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
