Question about Kitchen Ranges
Whirlpool gas range model WFG114SWQ0 - Kitchen Ranges
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: whirlpool gas range m#SF114pxsq1 diplays an F1 error code
HI. This is a basic Electronic Range Control Board failure code. I would advise to try a hard reset. This may correct the fault, if the damage is not severe. Simply unplug, or shutdown the appropriate circuit breaker for five minutes. After the five minutes have passed, kindly re-introduce power to the unit once more. Try to preform a baking cycle. if the code continues to illuminate during the attempt to operate the range, simply replace the main electronic control board(ERC or Clock).
Posted on Nov 16, 2009
oldTech2332
  • 2341 Answers
SOURCE: F1E1 code on whirlpool gold 30" freestanding gas
The E1-F1 error code means that the oven control board has detected a error within the board itself and the control needs to be replaced. The error code can be cleared by pushing the cancel/off button and if it returns shortly thereafter the control defeintly has a defect and should be replaced.
The part number for the control board is W10157245 itcould purchase it at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE-->-->
Posted on Sep 17, 2011
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
Whirlpool range XFG361LVQ2 manual
I need natural gas orfice for this model whirlpool gas range xfg361lvq2 to convert it from lp gas to natural gas.
Mar 22, 2013 | Whirlpool Kitchen Ranges
Gas range thermastat
Manufacturer Number W10159016
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-5-655221-/Whirlpool-Oven-self-cleaning-problem-SF3020EKQ3
Nov 05, 2012 | Whirlpool GS460 Gas Kitchen Range
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
Whirlpool Range keypad partially not working
Could not find any other way to contact you - have you found a solution? I am having the same problem with the exact gas range model.
Thank you,
Dan
Jul 31, 2010 | Whirlpool GW397LXUS Stainless Steel Gas...
Whirlpool model SF385PEEQ0 Gas stove was on Natural gas we have propane is there an adj or part needed as burns yellow flame!
You need to adapt your range for the propane gas. You need to change the orifices, propane needs a larger opening than natural gas. If you contact your propane company they can help you and some will even do it as a free service (or used to).
Jun 18, 2010 | Whirlpool SF325 Gas Kitchen Range
Our Whirlpool just started showing the following
E2 F1 - UL A/D error(s)
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Here's parts diagram for your model:
SF379LEKS2
Diagram#2 Part location#12 is your electronic control that you can order if you need to.
May 16, 2010 | Whirlpool SF379LEKS Gas Kitchen Range
Whirlpool gas range. How do I set oven to
Get the model # and serial # off the oven and contact Whirpool for the manual. OR, go online and see if you can ull it up. YOU MUST HAVE BOTH MODEL AND SERIAL NUMBER BEFORE YOU LOOK
Mar 30, 2010 | Kitchen Ranges
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
