Question about GPX "TL709B - 7"" LCD TV - widescreen - portable"
TD4022B NO ONSCREEN DISPLAY NO PICTURE.
RCA HD52W59yx30
If set and power light remain on check all connections and let me know if you see menu or any onscreen display.
Mar 11, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv made a pop sound and it has no picture know.
The first thing to know if your set on with no picture or will not come on. Do you see LED lit? If so there is a board in the back with pins you can short together to see if you have picture onscreen.This maybe a bad control board.
Short Pins 1 and 2 of P1 (Pin 1
is noted by a triangle) on Ctrl
PCB while the set is playing and
the pattern will display for as
long as you keep the short in
place
Dec 24, 2010 | Toshiba 50HP66 50 in. Plasma Television
Volume bar missing
Try changing your desktop picture. You may simply be covering it up
May 15, 2010 | Acer Aspire One PC Notebook
Our Insignia NS-30HTV picture is sort of hour-glass shaped on the edges. About 2-3 inches on each side of the picture is missing. How do you fix?
In my experience, this indicative of TV tube failure. However, just to be sure, try resetting the TV to factory defaults by entering the onscreen menus, select Picture, then reset. Also, power-cycle your TV (turn it off and unplug for several minutes). More details can be found in the owner's manual. If these steps don't resolve the display issue, you may call 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada to schedule in-home service.
Jan 10, 2010 | Insignia NS-30HTV 30" TV
Has sound but no picture
Are you able to view the TV's onscreen display menu?  If not, you have a problem with a video board and service is required.  If the menu does appear, you will have to check the cable/wire connection and make sure it is snug and in the correct location.
Mar 24, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Has sound but no picture screen completely black
If the TV is maintaining power but not displaying a picture or an onscreen display, there is a problem with a video board and it tend to be a capacitor problem and nothing to do with a fuse.  A fuse usually completes the internal circuit and if it were blown, you wouldn't have any power at all.  In any case, service is required as even a fuse is not usually serviceable by the owner on these newer TV's.
Mar 24, 2009 | Televison & Video
Recording. How to disable onscreen icons diplaying on record?
Go to camera Manu and check Display properties. There you will find display option on LCD or Video Output. select it Display On LCD.
Jul 29, 2008 | JVC GZ-MG130U Camcorder
Samsung dvd recorder DVD-R121, no sound(very faint) or picture (incl onscreen graphics)accepting dvds and is playing them according to lcd counter display
adjust your dvd by using your remote control..adjust the volume control,and set them through menu,if not working your audio ic is deffective.
May 13, 2008 | Televison & Video
Canon ZR800 Question
I don't think everything will remove off the screen. Your battery level and timers will remain on the screen at all times.
Sep 26, 2007 | Canon ZR800 Mini DV Digital Camcorder
GPX "TL709B - 7"" LCD TV - widescreen - portable" Logo
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
