Question about Samsung Televison & Video
Samsung tv cs14b500kj master code
Memory ic problem
MY TV SAMSUNG D8000 RESTART CONSTANTLY
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Nov 05, 2016 | Samsung Televison & Video
Samsung TV LA46B530 problems - flipping non stop channels
Oct 18, 2016 | Samsung Televison & Video
Tv channel lock up
It sounds that the main system control memory IC is faulty. Replace it and check. It is a very small IC, having 8 solder terminals, and can be located very near to main system control IC. Will look somewhat like this.
Jul 02, 2013 | Samsung Televison & Video
Samsung stuck on one channel
Do a hard reset to this set. Unplug it from AC mains wall socket, and re-pug it into after 10 minutes or so. This must make the TV a hard reset. If this do not help, make sure that the main system memory IC, a small IC, have 8 solder terminals, have damaged. It should be replaced. This IC can be located very near to main system control IC.
Jul 11, 2012 | Samsung Televison & Video
0nida tv why to any tuch rimort boton so of mument
English language without abbreviations would help you get an answer.
May 28, 2017 | Bushnell ONIX 200 GPS Receiver
I need the codes for a sanyo tv to program my philips universal
please find the similiar type of the tv (must good tv) remove both tv memory ic and copy from the good tv.use memory ic copier all settle ok
Jun 06, 2009 | Sanyo DS27800 27" TV
Java error no memory available
Source: http://en-gb.facebook.com/notes.php?id=49358857278
13.Dial *#6984125*#
14.Go to Internals (Master Key: *#9072641*#)
15.Go to Storage Settings and select Update Java DB
VODAFONE USERS TRY THIS CODE!!!
13.Dial *#3695147*#
14.Go to Internals (Master Key: *#3971258*#)
Apr 12, 2009 | Cell Phones
I need a code to program my tv controller to my tv
hard to find the code otherwise open up the ic memory then find out good tv same model duplicate the memory ic simple..the duplicater can buy from tv repair part shop
Mar 24, 2009 | Televison & Video
My samsung tv startup with full volume
Its memory IC is gone needs to replace check model spec or IC log book for yours model or email brand services to get IC number i.e. 8 pin ic any one with soldering knowledge can do that
Dec 25, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
