Question about Icom IC-V8000
Icom ic-v8000 can I use a HM-151 on the IC-V8000?
The HM-133V locks into transmit when I press the PTT. I have a HM-151 (came with an IC-7000), can I use that mic on the IC-V8000 without damaging either the transceiver or the mic?
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: Icom M710 Transceiver dosen't transmit.
Hi mesquaukee,
Are you trying to connect the SCS PTC-IIpro to an Icom M710 (or M700pro) marine transceiver? If you do kindly refer on the information below:
The audio connections are the same as the PTC-II/IIe, the radio-control connection is specific to the IIpro.
Audio connections:
PTC-IIpro Audio Icom M710 ACC(1)
(8-pin SCS DIN) (8-pin Icom DIN)
(Tx audio) Pin 1----(vio)-----Pin 4 (Mod)
(Rx audio) Pin 4----(grn)-----Pin 5 (AF out)
(PTT) Pin 3----(yel)-----Pin 3 (PTT in)
(Gnd) Pin 2----(wht)-----Pin 2 (ground)
(+12V) Pin 5----(blu)-----Pin 7 (12V out- see note)
Shell---(shield)---Shell
Notes:
1. The colors shown above are for the pigtail cable supplied with the PTC-IIpro. Check the colors with an ohmmeter, errors are possible.
2. The German-style DIN connector has a different physical pin geometry, and is not interchaneable with the US-style DIN connector used by Icom. Label the cable ends to avoid any confusion over which end goes where.
3. The PTC-IIpro has provision for an alternate 12V input on its HF audio connector. This provides a convenient way to connect power to the modem, but if the cable is particularly long then this could be a source of RF interference. Consider a separate power connection for long cables.
Remote Control:
Remote frequency-control is optional, but highly recommended when a PTC-IIpro modem is used with an Icom M710/M700pro transceiver. There are two options for connecting remote control to the radio, the recommended connection is to use the M710's 9-pin "Remote" connector (supported from Airmail ver 3.0.857 onwards). As an alternative, the 1/8" mini-phone "Clone" jack can be used, see "option 2" below.
PTC-IIpro "Control" ICOM 710 "Remote"
(13-pin DIN) (DB-9P 9-pin male)
Pin 3 (yellow) -------- NMI+ 5
Pin 8 (red) ----------- NMO+ 7
Pin 13 (orange) ---+--- NMI- 6 (see note)
+--- GND 9
Shell ----(shield)----- Shell
Note: Add a jumper between pin 6 and 9 on the 9-pin connector, so that the (orange) ground wire connects to both pins. Also make sure that unused wires are carefully insulated, short-circuits can damage the radio or modem.
Radio Settings:
In order to use the NMEA interface, it must first be selected using the front-panel "Set Mode" functions (turn power on while holding down the "Func" and "1" buttons-- or "Ent" and "1" for the 700 pro). Select the "REMT-IF" (remote interface) setting and change it "d-Sub" (or "RS-232" on some models). Also check that the "REMT-ID" setting matches Airmail's "AIcom Addr" setting).
AirMail Options Settings:
Modem (TNC) connection:
Modem type: PTC-IIpro
Comm port: COM1 or as appropriate
Baud rate: 38400 or 57600
Show link messages: no check
Ignore CTS: no check
Audio Tones:
Center Frequency: 1500
Check "USB"
Check "Marine (FSK dial=center)"
Amplitudes: as appropriate, start with 130/170
Radio connection:
Check "Direct using PTC-II control port"
RS-232: Checked (this is important!)
Radio type: "Icom-M710" (select appropriate model)
Baud: 4800
Icom Addr (hex): 01 for M710, 02 for M700pro, or 03 for M710RT (must match radio's REMT-ID setting)
Dial offset: 00
Note: Entering the radio modes with the "Modes" button is no longer required.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 14, 2011
My icom v8000 says off when I transmit how do I fix this
Hi
This sounds very much to me like a power supply problem.
If I understand your question correctly, the radio will turn on but when transmitting it shuts itself shuts off. This is usually caused by a poor connection to your battery. Although it is possible to show 12v using a voltmeter, there may not be enough connection when putting the circuit under load. (25 watts is a considerable load)
I would inspect both positive and negative connections (pay particular attention to the crimped lugs) , clean and lubricate them and give it another shot.
Here is a link to Trojan battery explaining in detail the importance of clean battery terminals.
Hope this helps you out.
-Steve
http://www.trojanbattery.com/pdf/WP_BatteryCableGuide_0512.pdf
Mar 09, 2015 | Icom IC-V8000
How to fix icom ic v8000 reversed polarity
you need to change the protection diode
Jun 15, 2014 | Icom IC-V8000
Ic 36 wont transmit
Check PTT switch is working? if working then check power output of your radio. if no power then change PA.
Oct 22, 2013 | Icom IC-M36 VHF Marine Radio
PTT switch IC 2820
Check PTT when you press it it must ground PTT voltage if it not ground the voltage then replace the PTT switch.
Sep 14, 2013 | Icom Radio Communications
S my icom ic-v8 turns off and reset when i press the ptt key
Hi Marc,
Great news for you: join yahoo group specific to Icom IC-V8, and there you can get all the info you require, plus you can download manuals, diagrams and lots of other goodies.
Best regards,
Peter
Feb 01, 2013 | Radio Communications
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
How can i reset icom ic- f30lt
press and hold the PTT switch while turning off and on again.
Aug 01, 2011 | ICOM Informatique W&W Manufacturing Icom...
Icom IC-V8000 Logo
32 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Lawrence Oravetz
Are you an Icom Boating Expert? Answer questions, earn points and help others
