Question about Kenmore Washing Machines
Search Fixya...110.29522801 I put a new water valve on was not getting any water had power everywhere still no water replaced water temp switch now have hot water but no cold what can be wrong now?
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
  • 619 Answers
SOURCE: KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Posted on Jan 10, 2008
  • 178 Answers
SOURCE: when temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Posted on Mar 16, 2008
  • 1314 Answers
SOURCE: water fill temp.
check to make sure that your hot water isn't connected to the cold side this is the number one cause for your problem all washers rinse in cold so if you switch to and its hot cold then your hose is on the wrong valve just switch the fill hoses see if that don't fix it
Posted on Mar 27, 2008
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
Posted on Aug 10, 2009
We were having a water pressure problem in the bathtub and were told to replace the 1222 cartridge no the hot water flow is affected everywhere.What now?
If it needs to be replaced then do that you might have to go to home depot to find out what you need to solve the water pressure problem usually the valves in the pipes could be an issue hopefully it's not something the plumber has to get involved with that can be pricey but call or visit your local Home Depot store so they can be better to assist you.
Aug 09, 2014 | Moen & Posi-Temp Single Handle Shower Or...
Rheem rr410T - my drain valve is leakin!!, I have now drained the hot water tank - what do I do now - just opened the cottage and had water everywhere after turning the water on...I am not a fix it person...
1) If leak is simple, then put garden hose cap over end of drain valve.
Pick up hose cap in garden department at home center or hardware store
http://waterheatertimer.org/images/garden-hose-thread-cap-76.jpg
2) Or install a garden hose and run to a drain until valve can be replaced.
The hot water will not last as long for showers until valve is fixed
3) If drain valve is cracked, it needs to be replaced.
If you are a DIY adventurer, then replace drain valve.
Since drain valve is plastic, expect to use every tool you can borrow when the plastic valve breaks off.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
4) Call a plumber who will prefer to replace with new heater.
5) If you want adventure, then replace heater yourself and save $400 installation. Here in Houston 2011, electric heater costs 220 and gas 330 at local box store. Offer 10% less.
Open following link for gas installation, and use basic information for replacing electric.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Good luck and Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water. everything works in order,but with cold water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 21, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
MY WASHER ONLY WORKS WITH COLD WATER. WE CAN NOT WASH CLOTHES USING HOT WATER.
check for 120volts on both water solenoids (hot & cold) as the solenoid could be bad,or the machine isn't letting power to the hot solenoid valve to open it,but frist make sure the hose screens aren't plugged and not letting water through these fill hoses to these solenoid valves
Jan 01, 2011 | Washing Machines
My Maytag Neptune FAV6800 washing machine overfills on the rinse cycle. Pulling the electric power does not stop the water flow. I have to turn off the water at the faucet feeding the hose. It seems to...
If you pull the power to the machine and water continues to flow then the water inlet valve is stuck open. You will need to replace the water inlet valve. The Service manual will step you thru the process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The water inlet valve is p/n 25001046 Substitution: 12002242 Water valve shop around for best price.
Is this Cold water inlet valve issue? If so and you only do Cold water wash/rinse like me you could switch the fill hose connections from hot to cold to hot at the faucet. Turn the hot water faucet valve off and select Warm/Warm temp selection and you will be filling with cold water wash/rinse. Maybe that would hold you over until you replace the Water Inlet Valve assembly.
You can check out your pressure switch transitions as I had this poster do for his issue at this link http://www.fixya.com/support/t5471295-washer_fills_water_begins_agitate_but
His issue seems to be a definite stuck pressure switch not water inlet valve such as yours. Check to make sure your pressure switch is OK by watching the fill point transitions as I mention in the post.
If you machine is a series 12 or above the Low and Mid fill pressure switch transitions will toggle at the same time. Series 12 and above us a 2 level pressure switch. Series 10 and 1 use a 3 level pressure switch.
Good Luck………….. D*ick
Aug 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water it too cold adjusted all the way hot . folowed procedure and adjusted the temp regulator all the way hot but still runs lukewarm at best.
Turn off the water at the main shutoff valve and remove the cartridge. Soak it in white vinegar for an hour to remove any varnish deposits and make sure that the parts move freely - or just replace the cartridge. I'm assuming that you get hot water everywhere else and that the cutoffs (if installed) are open and that no lines are kinked. If you're the original owner of the faucet PF will send a new cartridge for free.
Apr 17, 2010 | Price Pfister R897EBK Brushed Nickel...
Indesit moon wont restart after emergency shutdown
the motor likely got wet - check/replace the water inlet valve and let it dry out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Washing Machines
LST8244BQ0 Should I just get a new washer? Overflows with water, keeps on filling. Stops filling when you switch to rinse cycle from wash cycle though. Drains well. I may have overloaded when I was washing...
Simple fix. But you might need a tech. Sounds like your water level switch needs fixed or replaced. Most work on air pressure. (Huh? your saying? :) A tube (you can't see) runs down the verticle length of the tub. As the tub fills with water the air in the tube increases the air pressure within it. There is an air pressure switch on top of the tube and the "Washer Load Size" switch adjusts so that when the air pressure is correct (water level in the tub) meets the requirements of what you set it to, then it turns off the water inlet valve and starts the washing cycle.
If this "water level tube" gets disconected, it will not work. Also if it gets cracked (it is plastic) or gets plugged somehow, or if the switch fails, you wil have water, water everywhere.
Here is the manual online -
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LST8244BQ0&siteCd=WHRCOM
Whirlpool's Toll Free number is number is: 866-698-2538
and thier customer service Web site is: http://www.whirlpool.com/custserv/index.jsp
Hope this helps - If so - Check "Fixya" below!
Len
Jul 26, 2009 | Whirlpool Washing Machines
Washing Machines Logo
46 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
