Question about Garden
Task force electric lawn mower model 25043
What electric motor brushes do it use
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have an old Black and Decker 18 electric mower
Here is the black and decker website:
http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1498.1670
Most the old models where 6 amps. 1/2 hp
You can get another one from ebay or craigslist
Posted on Sep 04, 2009
SOURCE: Morrison 1400W electric lawn mower goes for 20 secs.
I would think that switch may be faulty? Or is it a momentary switch only?, if so, then you have an input to the controller problem, insomuch as it starts, runs, for some reason thinks there is a problem & shuts down, whereby the switch is being pressed, so it "Sees" this and starts again, and so on?
Posted on Mar 04, 2010
SOURCE: scott bonnar lawn mower service manual model 520...
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
Posted on Sep 21, 2010
  • 160 Answers
SOURCE: I have a Yard Machine
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
Posted on May 02, 2011
I need the electrical motor P/N 90565704-04.
Do you need a new motor or is it just the brushes which need replaced? Firstly unplug the machine and disassemble the motor or gain access to the brushes, found on either side of the motor at one end only. Remove the brushes (they usually unscrew behind the black caps), if they are burnt or look badly worn or are less than 5-8mm in length, replace them. The BRUSH is the black carbon rectangle of hard material at the end of the brass spring. New brushes are often 25-30mm in length as a guide. Based on that information you then decide if new brushes or a new motor is the answer. A quick tip; If you remove the motor and clamp it safely, connect the correct voltage to the motor lead and switch on long enough to establish if it is working and running freely. If you cannot find the parts locally, try www.4ourhouse.co uk.
Apr 17, 2016 | Black & Decker Black and Decker Mm575 18"...
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Stuck brushes,in the brush holders caused by corrosion,unplug the cord first,remove the cover and look for two carbon brushes that should be contacting the motor,if not stuck they may need replacement !
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Electric Mower zapped?
They should replace it. They broke it. If it was just a cut in the cable it should work again, but they have probably burnt it out. Change the fuse first also as that would have popped.
Jul 13, 2013 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Electric Mower electrocuted?
wire disconnect in lawn mower.
Task force lawn mower 24 volt battery
Battery Source - if it's made they can get it but usually they use 2 - 12V batteries and wire them in series to get 24V
Mar 23, 2013 | Garden
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
My craftsman 12 amp 18"
If the brushes are really short, that could be a lot of the loss of power if they are not making good contact with the commutator. If you can not find your model number, see if you can locate an identical one or one of the same motor. You may have to try going into Sears to see if there is one on the sales floor and get the model number off that one.
Aug 24, 2011 | Electric Lawn Mower
Garden Logo
241 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
