Marsh gas furnace
Need a control valve for a marsh wall heater
SOURCE: williams 400dvx-r nat forced air natural gas furnace
thermocouple broke off inside furnace how do i get it out?
Posted on Oct 28, 2008
billyvangogh
  • 108 Answers
SOURCE: Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Posted on Nov 01, 2009
Testimonial: "I checked the pilot light and it's clean. I will have to check the chimney next week but thanks!"
  • 1214 Answers
SOURCE: Wires not connected to gas valve need wiring
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Posted on Dec 10, 2009
shastalaker7
  • 1515 Answers
SOURCE: Gas Furnace Will not light
Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
Shastalaker7
Posted on Jan 18, 2010
  • 37 Answers
SOURCE: I have a Dayton gas
The only thing you can do is get the modol and serial number off the furnice it self go to your local parts store and thay will tell you if that part is available ore not,thay will be abel to tell you for sure.
Posted on Jan 21, 2011
Testimonial: "Thanks for you help. I'll check it out right away."
Marsh single gas furnace won't light, gas valve have 24 volts , but no igniter or flame
May have to replace igniter They do burn out every so often.
I replaced mine twice in five years..
Feb 07, 2015 | Heating & Cooling
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ...
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Apr 11, 2011 | Empire Direct Vent Wall Furnace;...
Cant figure out how to relite my furnace
on the bottom of the unit there is an access door remove it and behind it you will find a gas valve and a pilot find the piolot......turn off the gas valve and move the selector to piolot depress the switch and at the same time place the flame from a log lighter onto the pilot light after this lights turn the gas valve to run and the burner should light.
Mar 03, 2011 | Empire Direct Vent Wall Furnace;...
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Dayton 3e735 standing wall furnace
Wall furnace? maybe and maybe not! if there is a way it would be on the gas valve and be labeled (though it might be hard to read). often the adjustment screw is under another screw but always labeled.
Feb 03, 2009 | Dayton Gas Furnace Heater
I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Dec 08, 2008 | Dayton 511 Utility Heater
Williams 400dvx-r nat forced air natural gas furnace
Power should be shut off at the breaker. Check with a meter before disassembling wires. The gas line gas valve will be at 90 degrees of the gas line when off, however to make sure, try and start the unit with the gas valve at 90 degrees. Remove the front cover of the unit and look for mounting bolts. From the outside, remove the vent screws. The unit should lift off its mounting bracket and slide toward you.
Sep 13, 2008 | Heating & Cooling
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
