Question about HP PSC 2410 All-In-One InkJet Printer
Hp 2410 paper feed problem
The paper does not feed all the way into the tray in the bottom and there is no obstruction in the machine itself.
    Sergeant:
  • 390 Answers
This sounds really dumb, but take out all the paper, open the unit and with a torch check for tiny jam of paper in roller or a ujo (unidentified jamming object!) now, using only a very small stack of paper, the correct type for printer, and carefully checking you have it in thew correct paper feeder hole, sit the paper gently in the feeder tray, do not force it in, make sure the stack is only small, and no curls or nicks in the paper (or bends or folds). Try again.
Posted on Aug 31, 2007
  • 20 Answers
Ok, no obstruction the paper should go all the way in. Check the side to side paper width adjusters.Too much paper by chance???
Posted on Aug 29, 2007
SOURCE:
HP Laserjet M2727nf 's scanner
If the problem is ALWAYS, can be caused by an error in the configuration of the white paper size. That is, the printer has a conflict of comparing the original document size and the size of the white paper.
If the paper has left marks from objects obstructing the paper path. This alone can resolve the paper feeding disarm until you check that the sensors are free of obstructions.
You can also clean and well make sure they are free of any problems and ensure that the paper path goes smoothly.
Try also check the good condition of the rubber paper feed, paper separation and drag.
Feb 08, 2012 | HP Laserjet M2727nf Multifunction Printer
Hp 2300d paper stops at exit roller
Probable causes: First have you tried running the paper thru the manual feed tray and see if it stops at the fuser unit.. if so then proceed with checking the exit area of the printer(fuser) and make sure there is no obstruction blocking the path, could also be the fuser actuator, small black arm generally pushes the paper during it's delivery(exitiing) of paper.. Worst case scenario is a paper feed timing issue.. but first check the exit area of the printer and the paper tray.
If you need further help, reach me via phone at https://www.6ya.com/expert/howard_563901c2e8628759
Feb 08, 2012 | HP LaserJet 2300d Printer
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
Paper feed issues
The problem is what you already stated, the rollers are too smooth so they are not grabbing the paper to feed it.
Try this : clean with alcohol and a clean cloth very well and make a copy it will probably make one or two then jam.
order the tires and replace. should cost you about $20
Nov 06, 2007 | Office Equipment & Supplies
HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
[email protected]
Oct 14, 2007 | HP LaserJet 1320n Printer
HP PSC 2410 All-In-One InkJet Printer Logo
215 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
