Question about Fujitsu Computers & Internet
Some keys keyboard don t work
Numbers 986 are not working across the top
alocenar
  • 293 Answers
SOURCE: don`t F keys...
is it sticky or not clicking at all?
Posted on Apr 01, 2008
SOURCE: My Gateway keyboard (#2520796)
Is your Num-Lock Key working?
Posted on Jul 01, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Special keyboard keys not working.
You need install or reinstall the driver software that came with the computer this keyboard was supplied with. Windows itself doesn't know what those keys do.
If you are still using that computer and you haven't erased the original factory software, the drivers should be in a directory somewhere on the hard drive. Compaq usually has a folder called "compaq" on the root (that is, it should be c:\compaq) and a folder in that called "drivers". This isn't always true, but the drivers you need should be in a similar folder somewhere.
If you don't have the drivers on the disk, you can download them from the HP/Compaq website, but you'll have to have the computer model number.
Posted on Dec 06, 2008
SOURCE: help with my short cut keys on keyboard
you can try googling your keyboards brand and you will most likely need to download software to set up your short cut keys.
Posted on Jan 15, 2009
anas12ka4
  • 76 Answers
SOURCE: four keys at top of keyboard do not work: 5, 6,-, =.
use the right side num pad, instead of repairing the keys,
Posted on Feb 10, 2010
Some keys on my toshiba laptop dont work
you could try and take the keyboard off and clean it or just replace it with a new one.
Mar 19, 2017 | Toshiba Computers & Internet
Monitor not working when plugged into laptop
On some laptops, you need to enable the external monitor port. Look at the number keys across the top of the keyboard. There should be some legends in blue on them. These are associated with the Function (Fn) key. One of the blue legends will most likely activate/deactivate the external monitor port. Press the Fn key along with the associated number key to activate/deactivate the monitor port.
Sep 06, 2014 | Envision Computers & Internet
Hp laptop number keys will not work at top
if hp laptop does not work a the top
1. check the shift key maybe it is working
if it is working
2. go to settings. you will see keyboard setting click on it and access the settings very well
Jul 31, 2014 | HP Computers & Internet
I want to remap the number pad where the 1,2,3 numbers are across the top and 7,8,9 are across the bottom. How do I do this?
A Google search netted this free key mapper:
https://lifehacker.com/5883003/the-best-key-remapper-for-windows
Jan 08, 2018 | Dell 0Y3740 Keyboard
Ti89 responds to resets but nothing else
If the calculator is several years old it may be showing its age.
There is a connection point between the keyboard and the display
that over time loses its efficiency. Try this: press a number key
and at the same time apply pressure with your thumb or index
finger to the region of the calculator just below the display.
If you press hard, the number may just show up in the display.
This is a test for the tightness (or electrical efficiency) of the
keyboard-to-display connections.
Another way to make this test is to twist the calculator while
you depress a number key.
Sometimes the effect is such that the keys on one side or the
other work, or don't work, and the keys in the middle don't work
or work okay. By twisting (don't break it!) the calculator body
while you press the keys will show the weakness of the
connector between the display and the keyboard.
This can be repaired by a good electronic technician if you
explain to him what I just told you.
Aug 29, 2011 | Texas Instruments TI-89 Calculator
How do you knock off the numbers in blue on the letter keys please
If you look just above the number keys across the top of the keyboard, there should be a light on when you press the FN key. Press the corresponding Fnumber to release the key lock.
On my keyboard the keys are F10 and F11.
Hope that helps.
Mar 30, 2011 | Samsung Computers & Internet
The e key does not respond
Go to your system preferences and select speech, then text to speech at the top. Uncheck "Speak selected text".
Nov 24, 2009 | Sony vaio VGN-T 1-478-986-81 Keyboard
Top letters pressed also types the above numbers
Hi there.
After a liquid spill on the keyboard and you have done your best to clean it and the keys still do the same thing, your only option is to replace the keyboard.
I have come across this problem many times, some keyboards you can clean and bring them back to good working order and others you have no choice but to replace.
Liquids like soda or sweet coffee do the worst damage to keyboards.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Apple M9034LL/A Keyboard
Nov 18, 2008 | Compaq Keyboard
Jun 05, 2008 | Gateway 2520796 Keyboard
Computers & Internet Logo
32 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
