Question about Plumbing
Kinetico model 50 service manual
How do I reassemble model 50 water softener?
2 Suggested Answers
  • 25 Answers
SOURCE: MY KINETICO QUAD 50 QUIT
Hi Dale,
I worked at a Kinetico dealership for 6 years. I am very familiar with the quad 50. Unfortunately, Kinetico can only be serviced by a kinetico dealership, or someone who has the parts and the know how. They can be difficult to diagnose and fix if you are not familiar with them. You say you want to change it out and replace it ? You might be better taking it in to a kinetico dealership and having it serviced. They are worth it. If not, you can go on the internet and shop for a water softener. www.ohiopurewater.com or www.discountwatersofteners.com
Posted on May 05, 2011
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
Brine tank fills but doesn't draw it back into the water sosftener
Your injector is stuck. Your manual should show you, at the least,
a diagram; you'll need to clean out the center of the injector and lubricate the seals or o rings with silicone grease. You cannot use Vaseline; it'll attack the rubber. You should bail out the excess water from your salt tank. After you've got rid of the particle of dirt from the venturi in the injector and lubricated the seals or o rings with silicone lubricant, reassemble. Three manual regenerations over the next three days should bring your softener back to full function.
Mar 01, 2015 | Kenmore 350 Series Water Softener
Kinetico reverse osmosis water flowing very slow
I am guessing you have checked to make sure the water flow into the osmosis system to make sure it is at proper pressure? If so is this a whole house system or just for the kitchen? If it is a whole house do you have the same problems in other parts of the house?
Jan 21, 2013 | Refrigerators
MY KINETICO QUAD 50 QUIT MAKING SOFT WATER. LOOKING ON HOW TO CHANGE OUT AND OBTAIN TO REPLACE
Hi Dale,
May 04, 2011 | Plumbing
MY GE WATER SOFTENER QUIT WORKING PROPERLY AFTER 6 MONTHS ,I HAVE HAD SERVICE CALLS AT $150 EACH TO NO AVAIL IT DRAWS SALT BRINE MY WATER HARDNESS IS 17 I HAVE SOFTENER SET TO 22 .I HAVE PRE WATER...
What is it doing? No soft water? What is the water analysis? Try manually regenerating 2x in same day. Make sure a bypass valve is NOT open. I need more info to help.
H2O Services
Jan 17, 2011 | GE 30000 Grain Water Softener GXSF30H
Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
Water softner dirty water
you might also want to check into the piping in your house is it gavinized, cpvc or copper, this could also make a diffrence, you could also be pulling mud from the bottom of your well, the anoid rod in the water heater will keep you from seeing this in the hot side lines,suggest to have a test done on the water take a jar with a lid and take it to your local plumbing supply house and see if they can't have it tested then you will have all your answers, the test i'm in md. it cost us aprox 40.00 to have the complete water test,
May 27, 2009 | Water Heaters
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Plumbing Logo
59 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
