AEG OKO LAVAMAT 72720 - Washing Machines
SOURCE: AEG Oko-lavamat 538 manual
www.manualshark.org/manualshark/files/5/pdf_10471.pdf
Posted on Dec 10, 2008
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: aeg oko lavamat 72600 update, ce error code
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
kapishtech
  • 2272 Answers
SOURCE: AEG OKO LAVAMAT 72630 is showing E20. what does
Error code E-20 means drain problem. It means that the machine is not draining water correctly. Check the drain hose, to see if it is kinked or folded over. It could also be that the drain pump or drain hose are clogged. Drain the pump (check behind the little panel at the bottom right of the machine), first draining via the small emergency drain hose if you want to avoid a large puddle.
Also get the fluff filter removed and checked.If the filter is clogged then it will not let the water to get drained. The fluff filter is behind the little trapdoor below and to the right of the drum on the front of the machine. Open the door, unscrew the filter, and pull it out. It will be covered in smelly slimy multi-coloured fluff, which you need to remove. When you remove the filter, there is a good chance that a fair bit of water will come out at the same time, so, if you can place a very low bowl or similar below the filter before you unscrew it it will save you from having to mop the floor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 28, 2010
SOURCE: how do i reset a aeg oko lavamat 72620 washing
how to make reset to AEG OKO lavamat 61600
Posted on Nov 14, 2010
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Hi can anyone help me please im looking for a user manual for an AEG oko lavamat 75620 washing machine
do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
Mar 17, 2013 | AEG Washing Machines
MY aEG OKO-LAVAMAT 610 WASHES BUT DOES NOT EVACUATE.
Check the drain filter, see if the hose is not clogged (blow it), verify proper operation of the pump and the pressure switch if necessary
May 30, 2011 | AEG Lavamat W1050 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
