Question about Motorola Mobility HS801 Consumer Headset
My phone once paired with the HS801 but unpaired and wont pair again...
I cut both bluetooth's off then back on and they still dont pair. My phone says it cant find the device now. In theory if it did once, then it should again right?
    Sergeant:
    Champion:
  • 359 Answers
My Bluetooth is stop pairing with my ipad
To get help pairing a Bluetooth accessory-like a wireless keyboard-to your iOS device, try these steps:
1) On your iOS device, go to Settings > Bluetooth and make sure that Bluetooth is on. If you can't turn on Bluetooth or you see a spinning gear, restart your iPhone, iPad, or iPod touch. Then try to pair and connect it again.
2) Make sure that your Bluetooth accessory and iOS device are close to each other.
3) Turn your Bluetooth accessory off and back on again.
4) Make sure that your Bluetooth accessory is on and fully charged or connected to power. If your accessory uses batteries, see if they need to be replaced.
If you still can't pair or connect your Bluetooth accessory.
1) If you previously connected your Bluetooth accessory to your iOS device, unpair the accessory, put it back in discovery mode, then try to pair and connect it again.
2) If you can pair your accessory with some devices but not your iOS device, unpair the accessory from your other devices. Then try to pair with your iOS device again.
3) Check with the accessory manufacturer to make sure that your accessory supports your iOS device.
4) If you still have any of these issues, contact Apple Support:
You can't turn on Bluetooth or the setting is grayed out.
You can't connect any Bluetooth accessories with your device.
The accessory manufacturer confirmed that your accessory is working correctly.
Sep 10, 2018 | Computers & Internet
My Bluetooth and speaker connect but it wont stay on after one or two songs it keeps shuting down kicking my Bluetooth off on my phone
Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
Hasn't cut out since pairing it again !
Feb 03, 2017 | Cell Phones
My plantronics savor m1100 bluetooth headset suddenly gives very bad static sound while making or receiving calls but a2dp is perfect sounding still. I want to know how to reset this m1100 bluetooth...
Unfortunately, you will have to delete it and then pair it up again. It may be the only way to make the static go away.
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Radio Communications
I have my bluetooth on and have tried to receive files via bluetooth from other phones and from pc and i can pair with other device but not receive files.It says paired but not connected.Is there something...
Sometimes this happens because either you or the other person changes the pairing keys or remove your mobile from his paired list.
It can be solved by unpairing and then pairing again wwith the other device.
Go to settings in your wildfire, Wireless and network, bluetooth. Long press on the device name and select unpair. Also remove your wildfire from the other device's paired list. Then scan for bluetooth devices and pair again. This should solve this problem.
Also, when some device sends you a file via Bluetooth, there is a notification asking permission to receive file. Make sure you click on it and select accept.
May 31, 2011 | HTC Wildfire Cell Phone
Iphone 3GS not pairing to plantronics voyager 520
Without turning the headset on, turn the bluetooth on for the phone. Select the headset that is paired, and select Unpair. Then turn bluetooth off. Put the headset into the "discover" mode, by holding down the power button until the light flashes red and blue. Then turn the bluetooth on for the phone, and it should "discover" it. It should ask for the passcode, normally 0000. Once you enter that, it should pair. After that, you should be alright. You can turn the headset off and back on again and it should connect right away.
Hope this helps.
otherwise try this : http://www.plantronics.com/media/media_resources/easytopair/
Jan 12, 2011 | Apple iPhone 3GS Black (16 GB)
I was paired to one phone, now I need to "unpair" because that's what Verizon told me to do, the phone pairs, but won't connect.
No such thing as unpairing, remember that not all bluetooth devices are compatible. A complete list of phones that are compatible are located on motorola's website, under consumer products, bluetooth. BTW, if you don't know the pin to pair the devices is 0000
Jul 31, 2009 | Motorola Mobility Bluetooth Car Charger...
Bluetooth Motorola Hs801 Pairing
after hs801 is switched on, hold one of the volume buttons till the LED(blue) stays ON, then you can pair device to any phone. Pass code is 0000.
Oct 24, 2008 | Motorola Mobility HS801 Consumer Headset
Detect & Connect Motorola HS801
HS801: Enter pairing mode by simultaneously holding down volume and Connect/disconnect key (Chrome finish key next to blinking BLUE LED.) When BLUE LED is steady, headset is in pairing mode. LG TU550: Menu key (top left button) Select SETTINGS; '5' CONNECTIVITY; '1' BLUETOOTH; '1' BLUETOOTH on/Off; '1' ON; '2' DEVICE LIST; Select NEW (Top Left hand Button) LG searches for new device/s; . Select HS801; Press OK; enter password 0000. Connection is made when HS801 BLUE LED resumes blinking.
Apr 27, 2008 | Cell Phones
Problem pairing
just after turn on both's blutooth. turn on blutooth search of headset also by pressing vol key for 3 sec.. then the blue light will turn on for few sec .. make search on mobile for blutooth device and u will pair it...
Nov 07, 2006 | Motorola Mobility HS801 Consumer Headset
Motorola Mobility HS801 Consumer Headset Logo
121 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
