Hp pavilion xt953 desktop
The computer was fine last night after I took the power supply out and reconnected everything, except that it kept rebooting itself. Now this morning it wont do anything except the little green power light on the back will come on
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
  • 12 Answers
SOURCE: Desktop shutdown. will not come back on. Green light flashing.
This sounds like it might be a power supply problem. If you are tech savvy enough you can do this. 1st try unplugging it, let all the lights go out and then plug it back in. Try to turn it on. It might work. If not, unplug the pc and hit the power button to discharge all voltages. Open the side panel and watch where all the cables go. Label if needed. Unplug all cables carefully. The ones on the motherboard have a clasp that holds them. You simply sqweeze the clasp and it should pull free. After all cords are removed, remove the screws from that hold the power supply itself in. These are usually on the back. Pull the power supply out carefully. Take the unit to your local computer store. They should have a tester to test a make sure that it works ok. Replace if necessary. If it is not the power supply you might try only plugging in the motherboard and HDD. Remove and boards using a static strap between you and a grounded (plain metal) on the case. after that, plug the unit in and see if it powers up. If it doesn't, it could be the motherboard or a video board you needed to keep plugged in.
Posted on Dec 30, 2008
lglalight
SOURCE: computer wont turn on
i had the same problem its going to be your power supply it probably burned out. when i changed mine it worked perfectly.
Posted on Jun 01, 2009
paand
  • 147 Answers
SOURCE: Can't turn Computer on. Green light on back flashing
I think there is a need of dusting the RAM and DIMM socket. Do the following steps:-
1. Open the cabinet
2. remove the RAM
3. Clean the DIMM socket(RAM socket)
4. Place the RAM again
5. Power on your computer.
Posted on Jul 15, 2009
  • 76 Answers
SOURCE: desktop with not turn on, green blinking light on back
Could have blown out your Power Supply to your PC. But I would at least try to unplug your PC and hit the power button to drain of any standing power, and then plug it back in and see if it will turn on. If not you probably at the very least blew out your power supply.
Posted on Sep 09, 2009
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Installed upgraded RAM in my HP Pavilion a1030n. Now computer will not power on even with the old memory put back in. what's wrong? Everything was fine until I unplugged the computer. I took off the...
YES. The slots are for different kinds of memory. ONLY use the 2 new cards and insert them into the SAME colour slots. You should NOT mix memory types. Forget the old modules.
Feb 14, 2011 | HP Pavilion a1030n (PS585AA) PC Desktop
Hp Pavilion a1120n will not power up.
Yes it needs a power supply. You can get a cheep one on eaby or get one off of the HP site
Hope this works,
Luke Wilcox
Dec 28, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Wirless keyboard and mouse and monitor do not work.
try takeing the ram cards and clock battery out and unplug the tower from the wall wait 1-5 min then plug everything back in this has worked for me several times on several different computers not sure it will help you but its worth a try
Dec 19, 2009 | HP Computers & Internet
I left it on last night. This morning it was off
check your power cord to insure that you are getting power. make sure power cord is plug in the back.
look in back of computer. you will see a little orange switch. it says 115/220 click to 220. boot computer.
if computer boots up turn off and click back over to 115.
if it does not boot your power supply in your computer needs replacement.
Nov 14, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
HP Pavilion desktop. Installed new RAM, won't power up.
the power supply seems to be fine> but we can check by removing the BIG ATX white connector on the motherboard> if the light is still on then the power supply is fine>>> then
we can first remove all the RAM from the motherboard> then connect the computer to power and then see if the Computer beeps or not> if it does the motherboard is fine > if it doesnt then the motherboard need to be replaced
Oct 17, 2009 | HP Computers & Internet
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Dec 12, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Wont turn on
Laptops are far more prone to be taken out by even minor power surges then anything else in your home, including desktop computers.
If you have any method (multimeter etc) to check the voltage from the power supply you may have been lucky and it took the bullet to save the laptop.
If the power is registering in the correct range, around 18volts, then chances are your laptop has taken the hit and the motherboard is gone.
If this is the case, then before you throw it against the nearest wall, take it to a laptop repair centre. It "may" have been saved by a fuse on the motherboard and therefore protected itself as best it could.
Prices to have it looked at will vary alot, so call around.
May 24, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
David Payne
David Payne
