Question about Royal 1610X Shredder
Power won't come on
Seems to be jammed with paper, made a deep grinding sound before losing power. tried to pull out paper, but still nothing. is it a fuse?
  • 35 Answers
Try to open the shredder with a screw driver, but be very careful not to break or move anything important. Remove any paper that may be in there. If its the gears inside that are not working, you can use some oil as a lubricant to fix it up.
Posted on Aug 27, 2007
6ya staff
SOURCE:
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
Will not shut down/ paper constantly jams. makes grinding sound
I had a 7170 series that gave similar, not quite as bad as yours, problems. Lexmark is a good name quality all in one. But, I believe it's time to upgrade. These rollers and drums are very easily put out of sync. And from there on you'll have nothing but troubles. The scanner situation is probably forming a very light coat of rust on the out rail and causing it to hang up. I honestly wouldn't put much more money or stress(your own) into this machine. Thanks, Dana.
Aug 21, 2009 | Lexmark All-in-One Printer with PictBridge
Grinding noise at startup paper jam indication (alarm flashes 3 times) no paper stuck in printer sounds like plastic gear is not meshing grinding sound occurs twice during powerup
definitely sounds like the drive gears are stripped, did it jam and someone pull paper out by hand this is major cause of stripped gears. generally fixing is not cost effective cheaper to buy new
Jul 07, 2009 | Office Equipment & Supplies
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Paper Jam & Flashing Light
take everything out and look at all the rollers and printer path and look in the back of the printer
Jan 15, 2008 | HP LaserJet 1320 Printer
Grinding noise and jamming
Try to pull out paper transport unit (when open paper cassette,there is green or blue andle on the printer) and check what is wrong.Maybe just something is in improper position.
Also check paper settings on printer and driver.
If you use 80-90 gsm paper-Plain, if You using heawyveight paper(more than 105 gsm untill 200gsm) -Thick.
BR
Dec 04, 2007 | Kyocera FS-C5030N Led Printer
Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Jun 03, 2007 | Shredder 1052 (Cross-Cut)
153 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
