Asko 10504 door leaking water but still can spin need a new door seal where can i get one uk
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
  • 236 Answers
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Posted on Mar 16, 2009
SOURCE: Water leaking from seals under tub; draining water on spin cycle.
Here is a website which might provide you with the internal diagrams and the facility to buy the necessary parts. Just enter the model number in the following displayed page and choose your model from the displayed search list.
click here for Appliance Parts Pros
Else will fetch you the direct link for the machine if you can provide me with the model number and the firm name.
All the best with the machine and in case of further doubts regarding my solution please do post your comments.Would be glad to help you out.Also please do rate my solution as the rating is very valuable.Thank you in advance.
Posted on Apr 10, 2009
  • 41 Answers
SOURCE: HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Posted on Sep 03, 2009
My Asko 10504 has started making what sounds like a metal on metal grinding sound when it spins. It's as if the whole drum assembly is moving more than it should and coming into contact with something,...
COULD BE THE TRANSMISSION SPRING OR TRANSMISSION BEARINGS. EVEN UR TUB BEARINGS IN THE TUB, A BAD MOTOR COUPLER HOWEVER U WOULD NOT GET ANY SPIN OR AGITATION IF THE COUPLER WAS BAD. BAD BREAKING SYSTEM WOULD NORMALLY MAKE NOISE BUT WHAT U WOULD GET THEN IS A COMBINED SPIN AND AGITATION DURING SPIN CYCLE,
Mar 23, 2015 | Asko Washing Machines
How to fix door leak in ASKO D3231 dishwasher
Almost sounds like the machine was dropped and is out of square. Can you take it out of the install location and check the squareness of it on the drum and the rails? Also if you take it all the way out of the cabinet, you can see the other hinge locations and check them.
Jun 11, 2014 | Asko Dishwashers
Asko 10505
cylicon can easily fill the gap. it works. you can get this from a hardware store in tube .
hope this helps
Apr 15, 2014 | Washing Machines
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
I have an asco 10504 washing machine. Very shortly after it starts the washing cycle it goes in to a fast spin. If I turn the power off and on a few times it eventually starts washing properly. This has...
Hi, Welcome to FixYa. Before I can accurately help diagnos the problem with your Asko 10504 I need to ask a few questions. Does the unit go directly into this spin with or without draining ? Does this occur regardless of cycle selection ? I will watch for your reply, please be patient if I don't respond immediately as we may be in different time zones as well as I am often working hands on repairs as I try to answer here at FixYa. Regards, Macmarkus :)
Sep 08, 2010 | Washing Machines
Leaking dishwasher
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 29, 2009 | Asko Dishwashers
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Water is leaking from the door especially when on fast spin
you need to get a new rubber door seal u can get it from this website http://www.4hotpoint.co.uk/cgi-bin/home.pl?gclid=CMKHz4OM05wCFZMU4wod5HwDKw to replace it you take the clip off the front of the washer the peal off the seal off the frame and the do the same off the drum then but the new one on.hope this helps.
Apr 13, 2009 | Hotpoint WMA48 Front Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
