Question about Dryers
Kenmore 110.86983110 automatic cycle not working
I have a Kenmore dryer with the Automatic Fabric Care feature. It is recommended to use the Automatic Cycle on the dryer which is suppose to measure the moisture in the clothes and advance the dryness control accordingly. However, the control does not advance unless you run the dryer without any clothes. It will advance as it should if there are no clothes in the dryer. I'm not sure what item(s) should be replaced in order to get the Dryness Control to function properly with clothes in the dryer.
myob247
  • 1342 Answers
SOURCE: Gas dryer runs too long
Sounds like you need a new timer.
The timer probably has a cam on it which triggers a micro switch
which turns off the timer clock motor.
Cams are often held in place with a set screw which might
have loosened and it is slipping.
Micro switch may have gone bad or has become disconnected.
if bad it can be replaced with a moderate amount of work.
Posted on May 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: My Kenmore Dryer model 110.86872100
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to two things mainly: Thermal Fuse, Wiring Harness. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance or else accept the solution if the issue is resolved.
Thanks
Rylee
Posted on Apr 03, 2010
charleshucke
  • 1114 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Quiet Pak 1
The electronic dryness control board is the issue, and it is quite common on this model, to go out, or be faulty.
Posted on Mar 04, 2011
  • 3074 Answers
SOURCE: I have a maytag gas
this should help. Tim:
http://www.applianceaid.com/thermo.html
Posted on Mar 06, 2011
TheMobilian
  • 8220 Answers
SOURCE: Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
Posted on Nov 07, 2012
86983110 dryer kenmore
There is a moisture sensor in the unit that tells the timer to advance. IT is not working. This could be a control board issue or bad connection.
Jul 08, 2013 | Dryers
Automatic sensor drying
Hello, Welcome to FixYa. As with most things each manufacturer seems to have their own terminology or "exclusive features" for their products. To answer your question, in a word...Yes. As a general rule "sensor" does indicate an "auto dry" cycle when properly maintained ( as long as the sensors aren't contaminated by way of "wax" build-up over the surface...clean regularly with a rag moistened by "white vinegar" if you us fabric softner or dryer sheets etc. ) and vented that will shut the dryer "off" automatically when sensing the items are dry...depending on the options and cycles selected of course. Hope this answers your question and thanks for visiting FixYa today. Please take a moment and rate the answer if satisfied or let me know if you require further assistance. macmarkus :)
Jul 12, 2010 | LG DLG5932W Gas Dryer
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
My Kenmore Dryer model 110.86872100 heats up and dryes on the touchup cycle but won't heat on the Automatic fabric care cycle
Hi
Thanks
Rylee
Apr 03, 2010 | Dryers
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Works on all cycles except that on the Automatic dry Miser setting the dryer stops mid cycle. All other cycles work fine and run through the complete cycle.
Inside the drum is 2 long metal trips that measure capacitance in the clothes as they get dryer. Sometimmes liquid fabric softener gets on them and stops the process. Wipe them off. They are right on the filter housing inside just below the filter.
Feb 20, 2009 | Dryers
Kenmore HE4 Dryer
rmcfarland I am going to make an assumption. You are using the Automatic cycle. If so then this is wet load detection. Open the dryer door and at the bottom on the front you will see 2 metal bars. This is you moisture sensor. Clean that sensor with a mult purpose cleaner. If detergent and fabric softner sheets build up a coating on this sensor, the control will think you put in a dry load and shut down the dryer. Hope this helps.
Jan 25, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore ultra fabric care
only thing i can think of without being there and able to test parts is your door catch could be faulty
Aug 10, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
15 people viewed this question
Top Dryers Experts
