Question about Maisto Rock-crawler Remote Control 4wd Truck
Repair doesnt work at all no power in either remote or car
Remote control doesnt open the doors,clock doesnt work
What make , model an year vehicle ! Sounds like some wires may have been shorted or broke , ripped etc....
Jul 24, 2016 | Cars & Trucks
Remote locking doesnt work with key also doesnt with interior switch. hazard switch located with interior switch doesnt work either
You have a couple of issues here and both should be addressed by BMW or a specialty shop. Your lock issue is the locks are out of sync and there's a specific procedure to re-sync. The hazard switch could be the switch itself or a wiring issue. I'd have BMW look at it, besides they warranty their work for 1 year after repair.
Feb 22, 2011 | 2001 BMW 330
Carrier Aircon WCARG010EE 1 HP (remote) It seems the fan doesnt work, and the remote doesnt work. and there is an Fr that keeps blinking.
You must check if there is power to the fan to confirm if there is failure of the fan motor. Since the FR display indicates there is possibility that the power is initiating.
If the remote unit is not powered from the main unit then it is possible that the main control section must be checked for failure in the control unit.
Check for faulty wiring to the remote unit-or a break in the wiring from the main unit. Check the received voltages on the remote unit.
Dec 09, 2010 | Carrier Heating & Cooling
Working fine until I changed batteries in remote, now I have no power on the console.
press the power button on the console to turn it on. if it doesnt work then u need to get it repaired or i fix it for free!
Jan 11, 2010 | Nintendo Wii Console
Sony xm gtx1852 amp new and worked for 1 day now is in protect mode even with nothing hooked up but the remote and power and ground.
meter the power side of the amp. sometimes the amp will go into protect if it doesnt have power. if power and remote and ground are good the amp is probably bad.
Dec 29, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Volume down button is not working
power reseting it should work, pop out the batteries, press every button twice and put new ones in, if that doesnt work a solder joint might have come undone, if your a techypop it open, if your not please do not risk voiding your warranty and call logitech fr a replacement or take it back to the store
Jan 23, 2009 | Logitech HARMONY 659 Remote Control
I have a concept cc-d800a amp. now it doesnt work?
If you are not an electronic technician you might not be able to fix the amp your self. You can replace the power fuse if the amp does not come on. If it lights up, with out blowing the fuse again, then hook up a speak to the amp and an input. If it plays good. If not and you are not an ET then take it to a repair shop. Amps can usually be repaired, if the cost of repair is not more than a new one.
Nov 22, 2008 | Concept CD-2410 Car Audio Amplifier
HORN DOES NOT WORK ON 1999 DODGE DURANGO
The horn is a simple circuit. Check your fuse, and see if you get power to the horn itself. The remote start and alarm are separate problems, and probably need a technician to straighten out.
Nov 15, 2008 | 1999 Dodge Durango
Mitsu vs60603 menu ?
actualy the only wat to reset is to unplug the power cord for 1 minute the plug it back in.
Aug 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Maisto Rock-crawler Remote Control 4wd Truck Logo
26 people viewed this question
Top Maisto Toys Experts
ray gallant
Mai Lor
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
