Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Hi where is the relay on a 90hrs power outboard
    Sergeant:
  • 456 Answers
Starboard side under plastic cover or mounted on tray starboard side
Posted on Oct 22, 2013
Outboard troubleshooting
sounds like a sticky relay . non repairable just replace with new relay.
Mar 15, 2014 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
I have a 93 explorer the wipers won.t work except on high i replaced the wiper motor and themultifunction switch still the same problem
I have a 95 explorer ... intermittent wiper and park not working. Hi and low works good. I replaced wiper run/park relay (R3146) Advance Auto Parts. Location underhood power distribution box left side outboard of brake fluid reservoir.
Apr 14, 2011 | 1993 Ford Explorer Limited
Evinrude 225hp will not power tilt batteries OK manual release will turn but still not able to tilt motor?
Check trim tilt switch (if that's ok ) Try the trim / tilt relay inside the engine cover.
Could also be limit switch above the trim motor up further under the motor.
My bet is switch or relay
Good luck
Aug 14, 2010 | Clymer EvinrudeJohnson Outboard Shop...
2007 Suzuki 200ho four stroke outboard - no power to starter
There is a neutral safety switch, also one thing I found is carbon build up inside the starter will stop it cold. Take and air gun to it and blow it out, (try it, It might get it,) if not, take it down to see what is wrong with it. The safety switch should be a micro switch on the shifter, a couple wires going to it. Check it out. Hope this helps.
Apr 28, 2010 | Boating
Hydraulic going low only, not lifting up in my bayliner boat
If this is an inboard/outboard you have 2 relays for the outdrive. One is for UP and the other is for Down. If this is an outboard you may only have 1 relay.
You need to work with what is there to diagnose the problem. The down relay is working. It has a wire that goes to the pump on the transom. The UP relay also has a wire that goes to the pump. Disconnect the working wire from the Down relay and put the wire from the UP relay (to the pump on the transom) in its place.
Switch up/down wires if this is an outboard.
This will make the Down relay work the pump in the opposite direction. If the pump itself does not work both ways the pump is bad. If the outdrive now goes UP the pump is good.
Most likely the UP relay is bad. But there is a Tickler wire on each relay to make the Relays work. Check for Voltage at the Tickler wire-when you press the Trim button for UP position. If you have power at the Tickler the Relay is bad if it does not respond.
Make sure you get the proper replacement part. Most Relays are Negative ground. But boats can use Isolated relays which do not ground through the case.
This second type of Relay may have the same number of terminals but internally it is different.
I also have a Bayliner with the OMC King Cobra in it and had to work on my relays too.
Apr 07, 2010 | Boating
Were is the fuel pump relay on a 90 s10 4.3
Driver side firewall left of Brake Booster. There are 2 relays ganged totogether. Inboard relay Fuel Pump Relay, outboard relay Air Cond. Relays secured with screw with a 7mm hex head.
Feb 19, 2010 | 1990 Chevrolet S 10 4WD
Relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Oct 30, 2008 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
54 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
