Question about Dryers
Ventamatic duostat The fan won't shut off at desired temperature until the temp setting on the duostat is adjusted slightly . Sometimes just touching the temp adjusting screw. Any ideas?
aborcass
  • 2651 Answers
SOURCE: Won't maintain a constant temp. Varies from +10 to -15
i doubt that.def sounds like bad cold control though,good news if your producing cold. Hair dryer good---- Ice Pick no good!!!
Posted on Feb 24, 2008
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
Posted on May 30, 2008
  • 7 Answers
SOURCE: Fan speed too fast
Is there a light switch control or just straight power to the fan? They do sell "Fan" controll switches just like a regular dimmer, but for a fan. If there is just straight power u would still be able to install a remote that could lessen the speed. Even if it is just pull chains. the remote would have three speeds and if u kept the pull chain on low, maybe the low remote speed could work.
Posted on Jun 11, 2008
  • 244 Answers
SOURCE: Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Posted on Jul 11, 2008
aborcass
  • 2651 Answers
SOURCE: oven temperature adjustment
well no need to fret, if you oven is heating over 100 degress off theres problably not an adjusatment to compensate for that, youll need to either replace the htermostat or the thermistor, depending on which your machin uses
Posted on Jan 20, 2009
Da99 samsung fridge freezer
As for freezer, lower the letter and allow 24 hours for temp to adjust. Lower again and wait, until desired temp achieved.
Do the same thing for refrigerator. If freezing not working most efficiently, this can and usually does affect the refrigerator.
Go to http://www.buzzle.com/articles/refrigerator-temperature-settings.html for more info.
Mar 02, 2014 | Refrigerators
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Fan runs long after room reaches desired temp. heat goes off and fan continues to blow cold air, have a protech 520 thermostat
Is your 'Heater' you are talking about-- A furnace-- with a burner and a blower?
Either way-- We need to adjust a control that determines WHEN THE FAN RUNS--
Most furnaces have a section where the heated air collects, and there has to be a sensor in that chamber, that senses when that air is warm enough to circulate around--- and when the burner shuts off, the air in that area cools down, and the sensor should shut off the fan-
Can you find the Heated air area?-- and can you find a temperature control in that area?-- Can you adjust the control, so that it shuts off the fan when the air temp drops to 100- to 120 degrees F...
Tell us more about the type of furnace/heater we are workig with, so I can better help you-
Tell us more
Mack B
Jan 18, 2011 | Heating & Cooling
I have the Reliance 606 and my water has been extremely hot - do I need to change both of the heating elements in it
Are you aware of how to adjust thermostat(s) on water heater? Be sure to shut off power (circuit breaker(s) to water heater prior. Should be behind covers on tank. Both should have screw in center to allow you to back down temperature. Should have an arrow indicating current temperature setting, simply move it slightly toward lower temperature (usually counterclockwise, but just double check ) and try it, until desired temperature is reached.
Nov 30, 2010 | RELIANCE ELECTRIC WATER HEATER
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
I have a magic chef 1.7 cubic compact refrigerator, it's been great, but I had quite a bit of ice build up on the little freezer compartment. I unplugged it, and used a hair dryer to melt the ice until it...
OK as long as you used a hair drier, and not a screw driver to defrost this machine, you should be fine, it shoudl take no more then 24-36 hours to regain the correct temp, this being said, not real comfortable with the over the internet diag of a unit that potentially "keeps people alive"
Jan 25, 2009 | Magic Chef MCBR170 Compact Refrigerator
Automatic Temp Control
I believe that is how automatic temp control works once the desired temperature setting is reached it should shut off then maintain this temperature thus kicking on and off. Or is the problem that its not getting to the temperature you are requesting.
Aug 05, 2008 | 1999 Mercury Grand Marquis
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
