Is there any possibility to use ip camera with Skype. I have purchased Edimax IC-3115W ip camera. Please let me know
How can we use IP Camera with Skype?
  • 3 Answers
SOURCE: IP camera keeps resets itself
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: Problem with IP Surveillance configuration
Can you view the stream in IE or IP surveillence or is it that you hit the camera in IE, the sign in box shows up (cause you put in a pasword), you put in the password, and it cannot connect and says retry.
Possible problems.....
The IP you are typing in is really not the IP of the camera (comes from the box being checked that says 'reset the IP on reboot') Use the installation Wizard to find the camera and it's IP.
Your firewall is blocking the stream. Try disabling it and reconnecting.
Your cameras IP is not in the range of the DHCP server of the router it's connected to. Review your router's DHCP list to see if the camera IP is in that range.
The password on the camera is corrupt. You will need to hard reset the camera and reset it back up from scratch to connect.
Worst comes to worse, you can always just hard reset the camera and start over.
  • 93 Answers
SOURCE: Can't find IP Address
Helo,
You want to find the localserver ip address U go to cmd- and then type ipconfig .U want the internet ip address u go to this site ip-detail
Posted on Jun 05, 2009
avastph
  • 92 Answers
SOURCE: cant see snc rz30n, appear ip ip setup window, won't load page
Enable network and then give ip in the address bar of browser the home page will be browse.
Posted on Jul 14, 2009
  • 4 Answers
SOURCE: how to reset to Default settings
turn on the camera, pressed holding the reset button.
Posted on Aug 23, 2009
I installed ip camera on my android phone and then installed ip camera adapter on computer but when i restarted skype and called someone it suddenly close
Thanks for the clarification crazyboy.
From what I have read, this is a known issue for the windows software you installed.
Skype says to remove that software from your computer via control panel, and then to install software called "ManyCam".
Then you need to point your sources to ManyCam in the Skype client.
The walkthrough, the ManyCam download link, and the place where I got this information are listed here:
http://community.skype.com/t5/Windows-desktop-client/skype-crashes-when-viewing-viedo-settings/td-p/1427523
And this is the extracted ManyCam link for you: http://download2.manycam.com/ManyCamStandaloneSetup.exe
And here is a YouTube walkthrough if you would like to still try and use that software you already have installed:
https://www.youtube.com/watch?v=fE4wJCMAagg
skype crashes when viewing viedo settings Skype Community
How to use the Skype video call in the IP Camera
Mar 31, 2014 | Microsoft Windows 7 Ultimate for PC
Lost ip address
They most likely mean serial number.
An IP address is issued by a router and can change from time to time when you connect to the router.
May 17, 2013 | Sony Cyber-shot DSC-T90 Digital Camera
I want to default ip edimax ic-3030 ip camera pls help
uninstall first the driver then install again the driver of ip cam. once you find the ip...this is your deafult ip.
Feb 19, 2011 | Computers & Internet
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Feb 12, 2011 | Uniden Wireless Security Surveillance...
I have an edimax IC 7000 pt IP camera, I am having problems getting it to work using port forwarding..I have the latest sw & firmware loaded but seem to be going around in...
You have forward 2 ports.
forward port 80
forward port 443
make sure you have typed in the proper ip address for your camera,
ie. check the admin thingy to get your ip address for the cam.
then check if you can access it locally, then call a friend to see if they can access it remotely.
R.
Feb 11, 2010 | Edimax Computers & Internet
I dont know how to view my ip camera over the internet from another location
Normally IP camera's have a build-in webpage that you can accses from remote location so that you can easly oversee all you camera's.
You should be able to connect to this webpage by entering your IP adress in the adressbar of your web-browser.
Check your manual?
Nov 27, 2009 | Edimax Digital Pan / Tilt IP Camera...
How to watch IP Camera on internet by using DSL-2640T??
let me give you few suggestions and then you can take it from there.
firstly IP camera is just what its name says..it needs a fixed IP address it may be local as in your lan where it is working or a IP address from ISP.
Now when you connect it behind router... it is essentially a camera connected to LAN.
now the problem is DYNDNS.com will give access to your router since that is connected to dynamic IP addressing. However Ip camera is behind router and to access it you need to open proper protocol and port in router .consult your router manual for doing that.
with your current setup that is the only solution. however you can connect Ip camera directly to ISP line and then use dyndns as in case of router. though i dont know how feasible that will be for you.you have not mentioned IP camera model so cant help with specific details.
Aug 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Apr 05, 2008 | D-Link DCS-3220 Network Camera
Edimax PS 3100A+ IP reset
First you must connect to the printer using lpt port. then that server automatically printing its information about it. example: IP address and ...
Aug 08, 2006 | Edimax PS 3100A+ (PS-3100A) Print Server
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
