Question about Radio Communications
REALISTIC 20112 POLICE SCANNER - Radio Communications
  • 192 Answers
SOURCE: is a realistic scanner a police scanner?
Yes.
Scanners do much more than just pick up police frequencies, but yes, the term 'police scanner' is commonly used in place of more appropriate names like Radio Scanner or Wideband Receiver.
Posted on Nov 13, 2009
BillB-SA
  • 2761 Answers
SOURCE: I have a pro 38 realistic scanner i need local
For a comprehensive database of active frequencies and systems in your area, plus a lot of other useful scanning info, visit
www.RadioReference.com
BillB
Posted on Feb 07, 2010
  • 3 Answers
SOURCE: i need to program my realistic police scanner.
for your frequency, go to the local radio shack and ask them to look up the frequency. If you have nothing to fear from your local jurisdiction, go directly to them and ask for the frequency. Programming is the easy part and obtaining the frequency not difficult.
Posted on Feb 16, 2010
BillB-SA
  • 2761 Answers
SOURCE: I need to reprogram my Realistic Pro-2023 police
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Posted on Feb 21, 2010
BillB-SA
  • 2761 Answers
SOURCE: Have realistic pro-42 hand held scanner
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
Bill B
Posted on May 11, 2010
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
Oct 19, 2014 | Radio Communications
Can you still hear police broadcast with a realistic pro-2020 scanner or has it become obsolete due to HD?
It would help to know your location. HD is High Definition. I believe you mean digital.
Mar 20, 2012 | Radio Communications
Have a pro 2020 realistic scanner have frequencies but they don`t seem to work. Can you please help?
See: http://support.radioshack.com/support_electronics/doc45/45530.htm
For a detailed "How To"
You may have frequencies that are no longer in use as most police, fire, and military have switched to digital radio which is not available on a scanner.
Dec 10, 2010 | Radio Communications
Bill B
May 10, 2010 | Radio Shack Pro-96 Scanner
I have a pro 38 realistic scanner i need local reno area police frreqs
BillB
Jan 31, 2010 | Radio Communications
Is a realistic scanner a police scanner?
Yes.
Nov 11, 2009 | Radio Communications
I need to program my realistic police scanner.
Jun 16, 2009 | Radio Shack Radio Communications
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
