Question about GPS
Ford Mondeo 2012 cryptnav blaupunkt TravelPilot FX UNITED KINGDOM IRELAND +MRE update
No updats found sd2-GBI+MRE_LSRNS_2009 v3 Title: FORD LSRNS GBI plus MRE 2009 Project-Number: P_FORD_LSRNS Project-Name: FORD LSRNS GBI plus MRE 2009 Worm: sd2-GBI+MRE_LSRNS_2009 v3 FX NAV-Server: DI_SWNAVI6.4 C1P19 Boot-Reg.: ford_lsr Default-Sprache: [_ g_ 01 m] deutsch Nav-Data: SD2G-Link_N10I9M7T6/nav2-FORD_LSRNS_GBI_2007.10_CCP_EUR_MRN_LG10 v2 Map-Source: SD2G-Link_N10I9M7T6/nav2-FORD_LSRNS_GBI_2007.10_CCP_EUR_MRN_LG10/ Map-Data: map2-FORD_LSRNS_GBI_2007.10_CCP_EUR_MRN_ML7 v1 TMC: c10ff-5.1 d01ff-6.00 a01ff-2.0 409ff-5.3 601ff-2.1a 817ff-6.1 225ff-2.41 551ff-1.3 f32ff-6.1 301ff-0 e17ff-2.1 501ff-2.1 909ff-8 617ff-1.42 f49ff-2.0 e33ff-2.0 Date: 21.08.08 Comp: SCCS-Vers 7.13 08-20-08 Img: ########### Versioninformation ############ # SW-Version : DI_SWNAVI6.4C1P19 SW-Freeze Date: 7.Aug.2008, 16:30:10 Speech : 7.3 RG_MAIN : 12 RG_SUB : 0 RG_DEVICE : 0 RG_FLINK : 4277 MAP : 7.9 TMC : 6.4 INDEX : 9.5 RNW : 10.4 TIMA Config : '95:35:2' Compression : 4 ### # Binary info of: ### SW-Version : NF_6.4C1P19 SW-Build hour : <17> SW-Build day : <7> SW-Build month: <8> SW-Build year : <8> ### # Binary info of: ### SW-Version : NE_6.4C1P19 SW-Build hour : <17> SW-Build day : <7> SW-Build month: <8> SW-Build year : <8> ########################################################################### ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ### # Registry version info of : ### DATE : 2008-08-07 REGISTRY_VERSION : DI_SWNAVI6.4C1P19 ###########################################################################
SOURCE: Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Posted on May 19, 2009
SOURCE: Map update error problem with Magellan 4250
You may the solution given at: http://tips4nongeeks.blogspot.com/2009/09/magellan-gps-firmware-update-issue.html
Posted on Sep 14, 2009
djsyco
  • 73 Answers
SOURCE: 2005 navteq maps update
The map update is available from Panasonc for $150, it is advertised for $300. But when you call to order it they will tell you it's $150, and it with come with a disk and SD Card. Just Follow the instructions to do the update, this update will also apply to the iPod video problem too. The number is 1-800-405-0652 and tell them you need to purchase CA-MAHD08U.
Posted on Nov 04, 2009
  • 1738 Answers
SOURCE: I want to update my blaupunkt travelpilot lucca
you have to use a usb cable and go to the manufactor website to download the updates.
Posted on Nov 21, 2009
  • 15 Answers
SOURCE: Blaupunkt TravelPilot 500 maps of Argentina / Chile
Hola, date una vuelta por http://www.proyectomapear.com.ar/ ahi en los foros seguramente encuentres lo que necesitas.
saludos.
Posted on Jul 27, 2010
Blaupunkt Travelpilot EX. What is unlocking code?
Was this vehicle equipped this unit,or aftermarket/add on ??
Aug 19, 2015 | 2005 Ford Mondeo
New battery fitted to my ford mondeo 2008 now blaupunkt radio/sat nav fx not working how do I reset, the unit does not power up
Check the fuses! If the fuse box fuses are ok check the one on the back of the radio...needs to be removed!
Jan 08, 2015 | Blaupunkt Car Audio & Video
Blaupunkt travelpilot fx not working, it is dead
how to use the instruction above if device simply doesn't turn on???
I cannot insert any discs when device doesn't turn on
Mar 27, 2013 | Blaupunkt Car Audio & Video
Radio code BLAUPUNKT TRAVELPILOT
pb050026351461 ::: 7612300502 ::: code svp
Mar 30, 2012 | 2006 Ford Mondeo 2.2
Can I get an instruction manual in English and update the maps?
I have an English copy of the instruction manual in PDF which I will mail to you , if you send your email address . Apparently so far there are no updates for this machine .
Holgate Ghost
Jun 30, 2011 | Blaupunkt TravelPilot Lucca MP3
Blaupunkt lucca.exe error
find update firmware from this site and update the firmware on the device or re install the software. http://blaupunkt.de/en/servicesupport/audio-pl/car-audio/downloads/updates/
Dec 30, 2017 | Blaupunkt TravelPilot Lucca MP3
GPS Logo
782 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
