Question about Health & Beauty
Rupp womb in lining of womb
Had scan last week bit no results yet
My last day of periods was on 28 April then I slept with a guy on the 14 of may now my womb is painful and I feel like vommiting am I pregnant ?
It is possible you could get pregnant, but since it has only been 5 days it is too soon to tell.
May 19, 2017 | Pregnancy
When do babies start breathing in womb?
they do not, they get oxygen from mom, but until they are born, then they breath
Apr 09, 2015 | Baby Care
There is a line across the page on all pages scanned through the feeder
If the line runs in the same direction the paper feeds, that being top to bottom not side to side, then there is something blocking the scanner. Most sheet feeders have a seperate glass that is used for scanning and that will result in bad scans from ADF but not if you scan directly from the glass. Clean the ADF glass with a soft cloth slightly damp with window cleaner. Look closely because even small bits of almost invisible goop like post it note glue can be enough to cause this type of image defect when scanning.
Mar 11, 2011 | Xerox Office Equipment & Supplies
I have a set of twins born today, good size, but they are having trouble standing as the back legs fall forward and they can't stand and nurse. Am feeding mom's milk to help strengthen but one still can't...
Could be due to weakness but you can continue to feed until it regains strength for the body. It can be due to malnutrition of the mother giving the weakness to the kid. You can also feed a little bit of glucose diluted into the milk.
If there is no result after a day please consult a vet for observation and diagonises.
Feb 25, 2011 | Hasbro Furreal Friends Newborn Lamb
Power went out last week. Can't print. The jobs
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Feb 15, 2010 | HP Photosmart C7280 Printer
I SEEM TO HAVE 'NO INK' IN MY TABLET PC INPUT PANEL PROGRAM
In the programs that don't work, check your ink settings. Mine kept going to white until I got them set to black as default.
NEVER use system restore unless you have already tried malware scans, spyware scans, virus scans AND registry repair programs to fix software related problems. It is a LAST RESORT ONLY, just like FORMAT C.
Feb 25, 2009 | Microsoft Windows Vista Ultimate Edition
My 2000 Pontiac Sunfire 2.2 5 speed wont move ahead.
you may have pulled the lines from the slave cylinder a tiny bit and 1 may have cracked i'd check the lines to your slave cylinder first for leaks, 2 plastic lines going inside the transmission on the drivers side near the front of the trans..
Jan 07, 2009 | 2000 Pontiac Sunfire
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Health & Beauty Logo
82 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
