Bizhub c6500 hi i have error code C-4712 FOR BZ PRO C6500
goodgold
  • 389 Answers
SOURCE: Error codes for Konica Minolta bizhub pro C6500
C6500 Scan sensor or scan problem
Posted on Jan 16, 2010
firecontrol7
  • 6161 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
SOURCE: konica minolta bizhub pro c6500 error c2452
Toner low density abnormality
When the developing motor/M (M21) is ON, the maximum detection value of TCR sensor/ M (TCRS/M) is the specified value and the difference
between the maximum detection value and the minimum detection value is over the specified value.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
ctf1800
  • 4402 Answers
SOURCE: Hi, I have a C6500
The fuser exit rollers are the light grey painted rollers on the exit of the fuser itself. There is a slider mechanism that when slid forward or towards the rear, will adjust the pinch of the roller. Primarily it is there to deal with what is called a waxing effect where the rollers physically leave an impression in the soft toner on thick stocks. Reducing the pinch for thick stock reduces this. However, when doing thin stock, especially letter size paper, jamming can occur if the pinch is not engaged since there is no physical contact to drive the paper to the next conveyance rollers when doing duplex or face down printing.
The slider can be found on the left side door of the fusing unit itself, near the front. Normal operation is in the middle.
Replacing the CDB is just one of many troubleshooting steps, it is not the end all to this.
The 3102 code you encountered has nothing to do with temperature and humidity. It is a code related to the failure of the fuser conveyance. Gamma correction is also unrelated because gamma correction is image related, not conveyance related.
I highly suspect that you are encountering this code because of some kind of failure related to the fusing unit itself, again related to the movement of the fuser, which usually is in motion during many test modes of the main body components. Check all the connectors to ensure they are seated properly. The previous document relates to what to check and replace related specifically to fuser pressure roller.
We do not leave fusers at the customers either. We have spares at the shop that we rebuild during slow periods. This is simply our own initiative, not the norm, and is also a part of our troubleshooting regarding fusing unit related errors that are not so obvious...it is part of the elimination process, as some fuser related codes can be caused in other areas, such as the CDB, a bad conveyance clutch or motor or simply timing adjustments that are out of the normal range.
PROBABLE CAUSES:
1.One of the gears in the fusing unit gearboxfails. The shaft for fusing unit gear/H has been changed so that it is now supported at both ends instead of just
one end. The gear is now made of a stronger material.
The new design has been incorporated into all bizhub PRO C6500 machines beginning with s/n A03U0000787. A replacement gearbox is available for
machines with lower serial numbers. For the machines with serial numbers between A03U010000788 and A03U010001446 the fuser gearbox is already
updated and only fusing gear /H (p/n A03U808811) needs to be replaced.
Note :See attached Bulletin Number5923.This only applies to bizhub PRO C6500. All other models have the new style. To viewthe PDF, Adobe Reader®
must be installed. Adobe Reader® can be downloaded for free from the Adobe® web site at: Adobe - Adobe Reader download - All versions .
2. The machine cannot determine the separation cam home position.
Check the following items PS16 (p/n 08AA 8551 2) and Release Actuator flag (p/n A03U 7244 00). Make sure when the fuser jam release green knob is
turned counterclockwise, the Release Actuator flag (p/n A03U 7244 00) blocks and unblocks PS16/PS17. Check to see if the sensor is disconnected. If
turning the Fuser Jam removal Knob does not change the position of the Release Actuator flag, then check the drive gears associated withM30 (p/n 27LA
8003 0) for broken or stripped drive gears andreplace them if damaged.
3. A one-way gear (p/n A03U 8093 00) is slipping in the fixing drive assembly.
Replace the (3) fixing drive gears with the modifiedFixing Drive Gear/M 22T (p/n A03U 8093 11) andthe fixing drive shaft/A (p/n A03U725800).
Please refer to the attached Parts Modification Notices for details. To view a PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for
4. Failed fixing limiter.
Replace fixing limiter (p/n 65AA53651).
5. Failed ICP14 on Conveyance Drive Board
Replace Conveyance Drive Board (p/n A03U H050 04).
Posted on Apr 27, 2011
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Posted on Sep 15, 2011
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Error code c0101
konica monalta c70hc error code c0101
Sep 01, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Bizhub c 6500 pro code 2840
help me Konica C6500 error code 2840. thanks
May 14, 2013 | Office Equipment & Supplies
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Konica minolta Bizhub C6500 error code 2424
Please helpme!
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Trouble shoot error code 2701 in bizhub c6500
Probably this would help you.
http://www.cleanerrors.com/fix/error-2701/
Plz dont forget to rate me....
Oct 19, 2009 | Canon BJ C6500 InkJet Printer
Konica Minolta C6500 Error Message
There is a paper somewhere in the copier. Maybe earlier you have a paper jam and one paper or just a part of the paper is still in the copier.
Most likely the paper is near the imaging unit.
Feb 28, 2008 | Computers & Internet
65 people viewed this question
jasbo
jasbo
