Sagem router EMTA - Computers & Internet
Does the motorola surboard sbc6580 modem have phone connetion
Hello:
Neither the SBG900 nor the SBG6580 have a phone jack.
A cable modem with a phone jack is called an eMTA (Embedded Multimedia Terminal Adapter: Cable modem Wikipedia the free encyclopedia.)
Most cable companies will only have one alternative to their own equipment when it comes to eMTAs. For example, Comcast only works with the Arris 722G: Customer Owned Arris 722G FAQ Comcast Help and Support Forums, and they'll insist that it can only work if you bought it from Best Buy.
If you wanted to keep your SBG900 or SBG6580 and have VOIP phone service, look into a service like Ooma.
May 03, 2014 | Arris SURFboard SBG900 Wireless Router...
Installed Cox Digital Telephone. They disconnected my fax line. I have a Dell 968 printer and what I read on line is that it is not compatible with Windows 7 and that I would have to update the prin
Most newer fax machine seem to short line 1 and 2 together and this will cause a VOIP modem "called an eMTA" to go off hook. Your fax machine should have come with a phone jumper that has only a single line "2 wires inside it", you should be able to use that jumper to attach your fax machine to your house phone wiring. If you use a standard phone line jumper it has both lines "4 wires" and can cause your eMTA modem to go off hook which could be why it was disconnected.
Jan 30, 2013 | Computers & Internet
I need an open nat on my sagem 1704 router for ps3 game mw3
I did it with Xbox.
Manually configure your console to have a specific IP address. I set my XBox to 192.168.254.254, with the subnet of 255.255.255.0 and the gateway of 192.168.254.254.
Then (on a computer) I opened my web browser and went to the address: 192.168.254.254
The name and password are both: admin
I clicked Adcances Settings, then NAT, then Virtual Servers.
I created a virtual server, named it, gave it the IP address of my console, and opened up the appropriate ports.
Once I saved it, it worked fine.
How to configure Windstream st 1704N dsl modem router for Xbox live NAT
Apr 02, 2012 | Computers & Internet
I need to reset my sagem fast 800 pe can you help
Most Sagem devices have a reset button at the back, next to the ports you use for inserting cables. You'll need to push it for about 30 seconds with a pen or a toothpick.
Mar 10, 2011 | Computers & Internet
I have a phone modem ( arris emta) , my internet was disconnected and i had to reregister to get back on line by unplugging the ethernet cable from my router straight to the modem in order for my computer...
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 02, 2010 | Linksys WRT150N Wireless N Router -...
Sagem Router lights 123&4 not lit!
Plug an Ethernet cable in to one of the ports and the other into your PC.
Dec 17, 2009 | Computers & Internet
Sagem Internet Radio cannot find VTuner
Check with your Sagem manual if it supports WPA encryption. If not. then enable WEP on your wireless router and then check if you are able to achieve a connection between sagem and wireless network.
Jun 22, 2009 | NetGear MP101 Super Service plus vTuner...
Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
