Question about Joal 132 Valmet Sisu 4 Wheel Tractor
How do u adjust a clutch on a valmet tractor - Joal 132 Valmet Sisu 4 Wheel Tractor
Hi a have a valtra valmet 6800 it drives in every gear first second third forth but only will drive in spliter one two and three spliter wont drive any ideas
go google and type in--operators manual for valtra valmet 6800 tractor
there is a pdf version in site www. valtec.Lv>catalogue>download that explains the shifting operation of the various levers for the different ratios
Aug 04, 2016 | Joal 132 Valmet Sisu 4 Wheel Tractor
John deere clutch adjustment
how old there usually a clutch adjustment under neath the tractor connects to clutch this is for old john dear
Sep 02, 2014 | Garden
Adjust clutch on 1974 sears ssts/16
You adjust the brake you get clutch. Can't a diagram downloaded. I will tell you. Loose nut on turnbuckle, turn it clockwise till clutch has 4 3/8" free travel on clutch. Tighten nut on turnbuckle. You have adjusted brake and clutch.
Dec 24, 2013 | Craftsman Garden
2n ford tractor stalls when i let the clutch out
Your clutch needs adjusted a little more. Not releasing all the way.
Dec 28, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Electric clutch adjustment
.012" is the recommended air gap for the electric clutch. Use a feeler guage in the slots beside the nuts and check in circular pattern. Go at least 3 complete circles with your guage when adjusting.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Clutch/brake adjustment
adjust clutch
Jul 06, 2009 | Garden
Joal 132 Valmet Sisu 4 Wheel Tractor Logo
49 people viewed this question
Top Joal Toys Experts
ray gallant
Are you a Joal Toy Expert? Answer questions, earn points and help others
