Question about Dryers
I have a Allen and Roth double ceiling fan and now the light will not turn off by the pull string, so we can not have the fans on with the light off-- ANY HELP?? Its only a year old ;(
I bought it at Lowes. the fan has one light fixture and a 3 bladed fan on each side.
    Top Expert:
  • Dryers Master
  • 34,089 Answers
The light switch may have failed. They tend to do that.
You don't say whether your fan has a remote control, but that could be the source of your light problem as well
Posted on Jul 09, 2013
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
SOURCE: ceiling fan with light fixture remote won't turn it off - help!
Think we've figured out that a neighbor has the same remote code as we do and we will have to change our code. (This fan is out on our screened porch and the homes are close together here.)
Posted on Oct 15, 2008
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
jmgldsmth
  • 1869 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
Allen + roth santa ana ceiling fan manual
What kind of wiring diagram are you looking for? fanman9952@aol.com
Mar 10, 2016 | Dryers
Allen + Roth ceiling fan with remote Model #: LP8242LCH. The light randomly turns on. Not touching remote. Any ideas how to fix it?
Change the frequency in the receiver & transmitter. Also, stay away from store brand fans.
Nov 22, 2014 | Dryers
Allen & Roth Eastview ceiling fan. How do I reverse to pull up warm air instead of blowing air down?
Look for a slide switch on the side of the housing beneath the motor. If the manufacturer wired it correctly, the up position will pull up warm air and the down position will blow air down.
Jan 09, 2014 | Dryers
Trying to install an Allen & Roth Ceiling Fan Model#LP8062 Help it doesnt seeem like the light open to change a bulb and the blades dont come off Help?
That's just a CHEAP store brand fan. Take it back and go to a real fan store and get a fan with at least a 13 degree blade pitch or at least 5500 CFM's
Nov 03, 2013 | Dryers
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Remote lightswitch won't work.
This may be obvious but you may need to turn the light on with the string and leave it on. Then the remote should work. Sorry if this doens't work or is too simple.
Feb 28, 2010 | Oasis Hunter 54' Ceiling Fan
My ceiling fan light will not work the remote will operate the fan but will not do anything for the light and it will not turn on or off with the pull string
Probably the remote receiver . I've had 2 Hampton Bay fans do exactly the same thing. Original receivers are pricey, and was only able to find from mfgr.
Feb 05, 2010 | Hunter Ceiling Fan Light Remote Control
Dryers Logo
79 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
