Compaq will not turn on
I have a compaqpresario cq60 615dxand it will not turn on the only lights I see are the wifi light, which is orange and a green light on the disk drive can you tell me what is going on?
Im just guessing that you might have last used your compaq with a multimedia projector... it might still be on an "extended mode." you can check this using another cable and hook it up with a separate monitor and see if your desktop will appear on that monitor. if it does, right click on the mouse and choose "graphics properties." Click on the "hot keys" and check which keys you should press to enable your computer.
Posted on Jul 09, 2013
  • 1019 Answers
SOURCE: wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Posted on Dec 18, 2008
  • 82 Answers
SOURCE: Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Posted on Apr 22, 2009
rockitman187
  • 2559 Answers
SOURCE: WIFi catcher
You can drive around with your laptop,You cannot look at the indicator and know when your near a "station" .You can however look at the wireless status page and see any available "stations". The led simply says that your wireless is turned on.You cannot do anything with the laptop turned off.You only need drivers if you don't have wireless drivers already loaded.
Hope this answered all your question.
Please rate this fixya
Posted on May 14, 2009
graysand
  • 558 Answers
SOURCE: Battery light won't stop blinking
your battery is not charging,use a old toothbrush and clean the contacts on the battery and do the same for the contacts on the computer.This should work if not you may have to replace the battery
Good Luck
Posted on Sep 05, 2009
  • 284 Answers
SOURCE: Advent 7094swf turned off and never turn on again
i would say the hard drive needs replacing
Posted on Feb 13, 2010
I have a Presario CQ61 that will power up into sleep mode. all the lights come on but the wifi indicator is orange instead of blue and all the lights just flash. Removing the battery and putting it back in...
the WiFi isn't on if it's orange press that key and it will turn blue when it is on..with the battery take it out , count 20 seconds then put it back in and it should work
Sep 21, 2013 | Compaq Presario CQ61-310US Laptop
Compaq presario f500 wireless not working
Hello, I too had the same problem: wifi card does not exist in the network switch and light orange. I solved it this way: I unscrewed the screws at the memory compartment where it also houses the Wifi card, next is the battery backup of the bios, I pulled gently on the battery connector and I shorted the two pins for 1 minutes, I reconnected the plug closing the compartment and access your PC and Wi-Fi switch has returned the little light blue and WiFi networks are detected. I hope that you too can be solved in this way. Hello Michael
Feb 13, 2011 | HP Compaq Presario F500 F700 and G6000...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
Hi have sr1200nx blinking green light no power took side off checked connections still not working any advice thks
Usually led flashes are a code that gives the problem.
Two sites that may help are;
http://www.user-guides.co.uk/download/compaq/compaqpresario/compaq-presario-sr1230nx-disk-download.html
Go to the end of this page to see code definitions.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph07107
for more generic data
Oct 26, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Wifi quite working after hibernation
Common problem with the f500 series. The manufacter's warrenty has been increased to 2 years because of this probelm. The wifi needs to be replaced.
Aug 01, 2009 | HP Compaq Presario F500 F700 and G6000...
Wifi won't turn on
xp drivers for compaq presario c700
May 16, 2009 | Compaq Presario V6310US Notebook
My wifi stopped working on my presario f 700. It shows an orange light.
switch on your wifi switch thats why it shows orange light.
May 08, 2009 | Compaq Presario Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
