Question about Chicago Pneumatic CP864 Dual Action Air Sander
864 cp The tool runs great until I put it to wood, as soon as it touches the surface it stops. I can manually spin it to get it going but its useless if I cant sand anything. I have tried changing the rpms with the button on the side but I am not sure what PSI to set the compressor at? I have tried a few but I get rhe same result.
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: my cp 864 dual action sander needs part
You could buy it from :-
http://www.toolsource.com/valve-kf124233-p-74658.html
Click on Add to Cart and then Purchase the Amount.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 17, 2010
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
Masterbuilt Smokehouse model 20070712 won't smoke wood chips at 225 degrees
I had this exact same problem with my Masterbuilt Smokehouse even when brand new. I notice there is some variability in the space between the top surface of the heating element and the bottom surface of the wood chip box. I measured about 1/4 inch between the two surfaces when the heating element was seated bottomed out and touching the wire grill below it. What I did to fix the problem was to gently (make sure everything is completely cold before doing this) lift up the end of the heating element farthest away from where it enters the enclosure just a little bit so that when you put the woodchip box in where it is supposed to go, the top surface of the heating element will now be in contact with the bottom surface of the woodchip box. This arrangement allows much greater heat to heat the wood chips during the part of the heating cycle when the heating element is on (naturally the heating element cycles on and off to regulate whatever temperature your are targeting for your food being cooked). Now, because of this contact, every time the heating element comes on, enough heat will enter the woodchip box to keep the chips ignited. My next step is I am going to put a small 1/4 inch thick piece of metal beneath the heating element and the rack that is under it to force the heating element to stay sitting 1/4 inch higher so that it is always in contact with the lower surface of the woodchip box. Making these improvements allowed me to continuously get smoke when the big smoke box was at 225 degrees F.
Without making this fix, the unit would stop producing smoke at 225. Hope this makes sense and helps you.
Aug 25, 2012 | Masterbuilt 20070106 Electric Smoker
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
How to troubleshoot a computer
it depends on what you think the problem is first you take out the memory and listen for a beeb if you here a beep your memory is good your fan on your proccessor is running you are ok there then take off the fan and cleanit with a hair dryer and toooth brush use the hair dryuer on the power supply after turnining on the cp with the procssor fan of barley touch the processor to see if it hot if it is the the processor is in good shape then close every thing up and go to freewarefiles .com and download cp testing program and cp info program. freewarefiles is a great place for tools and learning software anitvirus and andvace system care 3 will solve alot of your pc problems
Jun 25, 2010 | Dell (E210882) Motherboard
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Loss of power; Rancher 55
HI. FRIST OFF THOSE SAWS ONLY WORK GOOD AT HIGH RPM.NOW I ALWAYS SET MY HIGH SPEED AT 3/4 TURN AND THE SAME FOR THE LOW. WHEN YOU START IT UP, FIND A PICE OF WOOD THAT IS A BIG PICE OF WOOD THAN YOU SHOULD BE ABLE TO SET IT UP. IF THAT DOSEN'T WORK GET BACK TO ME THERE ARE OTHER THINGS YOU CAN CHECK. THANKS JIMBO
Aug 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
As soon as i apply my sander to the surface it stops sanding
hi a major problem with pneumatic tools is that nobody ever seems to oil them! try droping tool oil or a light machine oil down the air inlet and leave over night and then run the tool on full ,if this doesnt work then strip the tool and clean and make sure that the blade sealing surfaces are good
hope this helps ian
Mar 21, 2009 | Dynabrade 57810 Dynabug Orbital Air Sander...
How to use Hand Power Planer?
Power planers are wonderful little devices that move work along quickly and easily when you’re working on such things as decks and remodeling jobs. Just like a manual planer, this planes or evens the wood by shaving off enough to make a uniformly flat and even surface. Think of it as a wood shaver or an effortless sanding tool. It can take a warped edge off of a door and make it functional again or it can straighten out a piece of wood so that sheetrock will go on flat. These are very handy tools for those who like to work around the house. Understand what power planers can do. You can use them to smooth the edges on all kinds of wood or to bevel (make a cut for a joint that isn’t 45 degrees) door edges. They will level framing lumber and chamfer (make a 45 degree angle in) handrails and scribe (mark or score) countertops or cabinets and taper and shape wood trim. They’re a very easy tool to use and they save a great deal of time but, as with any power tool, you do need to spend a little practice time before you use this on a real project. Know how power planers work. They have blades that are mounted on a cutter head that spins at about 20,000 rpm. The planer sits on a sole plate, also called a shoe, and the front and rear shoes can be adjusted. The difference between these shoes determines how much wood is taken off when it’s used. There is a front hand grip that adjusts the shoes and so determines the depth of the cut. A power planer can remove from a trace of wood 1/64 of an inch to 1/8 of an inch with each pass. Know how to use the power planer. As with many woodworking and power tools, the key to using this successfully lies in holding and propelling it along properly with the right amount of pressure. Pressure is the most important dynamic used. Stand in a position that you can stay in while you take a pass with the planer. If you shift your weight, you’ll shift the pressure. Set the front shoes of the planer on the wood before you turn it on. Start it up, give it a second to get up to full speed, and then push it steadily with even pressure along the wood. Keep the pressure even on the front knob and the handle so you don’t gouge the wood deeper in one place than another. Be careful to hold the pressure steady as the front shoe runs off the end of the wood. Change the blades when they start to seem dull. You don’t want to wait until they’re smoking or throwing up powder. If you sharpen or replace the blades, do them both together as they wear evenly and replacing only one would give you an uneven cut. Unplug the tool before you touch the blades. Make sure to mount them completely according to the gauge bases that come with them. These tell you exactly how to set them in the correct position. Know how to safely turn the planer off. When you shut off your planer set it down on a wooden block and wait for the cutter head to stop spinning. Every time you use this, check the mounting bolts to make sure they’re still nice and tight. Remember your safety goggles or glasses. Wood shavings can fly all over. Once you get the hang of this, you won’t ever go back to planning by hand.
Aug 27, 2008 | Sheffield Hangzhou #532606 3" Adjustable...
Chicago Pneumatic CP864 Dual Action Air Sander Logo
87 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
