Honeywell th5110d1006 not working
The thermostat doesnt really respond to anything I do to it. If I have the cooling set to 78 and the heat set to 75 and let it run on auto or even cool the ac will run into the 60s and won't stop until I cut off the power to the circuit breaker. If I put the heat on then it will go to that temp but strangely will still blow out cold air, so I'm not even sure if the stat is displaying the actual temp. Is this a thermostat problem or do I need to replace the circuit breaker?.......please help
benmartinez
SOURCE: Heat pump that just blows cool air
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
Posted on Dec 24, 2008
SOURCE: Thermostat - Honeywell Chronotherm III
What you can do is try and clean the contacts. Open the door on the thermistat and remove the two screws, after that you can seperate the part that is mounted to the wall and the front panel. Look at the part that is mounted on the wall and you'll see the contacts that should be a copper color. They might be black from age. Clean them and you'll be surprised how well it will work after that.
Denis
Posted on Mar 15, 2009
greg_margo
  • 1959 Answers
SOURCE: AC STOPPED BLOWING COLD; ONLY BLOWS ON MAX MANUAL SETTING
Your AC is low on refrigerant; The AC compressor needs a minimum amount of regrigerant to run. If and when it does run (while low on refrigerant) the air coming out of the vents will not be cold. The refrigerant you require is R-134A and is available over the counter but if you are the least bit unsure as to how to add refrigerant, taking it to a garage that does AC recharging would be your best play. If you want to try to add refrigerant on your own you will need the following, 1LB can of R-134A, an AC hose adapter to deliver the refrigerant, and preferably an AC pressure guage to ensure you are not overfilling the AC line which will damage the system.
Posted on May 10, 2009
SOURCE: AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
Posted on May 30, 2009
  • 4 Answers
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
I live in an 1 bedroom apartment and ever since it's been getting cold outside i've been having problems with my heater. i have a honeywell pro 2000. at first on cool setting it worked perfectly fine. when...
Amy,
It sounds like the problem is with the thermostat or how it's wired. I would call whoever the repairman works for and get them to send someone else out on a "call-back". (A "call-back" should not cost anything unless it is for parts)
Nov 17, 2013 | Heating & Cooling
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
"Cool On" indicator on for the first time- system not cooling
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH5110D1006
Click on the Link Above. At the bottom of the page is the Downloadable "Instruction Manual" for your Thermostat.
Hope i Helped
Please Rate Me
George
Apr 30, 2009 | Heating & Cooling
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
