Question about Cycling
Next power climber
The pedals spin uselessly because it has become loose from use. the rod connecting the pedals spins freely without turning the chains or the wheel. what is the name fir this piece? how can i get it replaced and fixed?
    Champion:
    New Friend:
  • 219 Answers
The bottom bracket on a bicycle connects the cranks (arms that the pedals are connected to) to the bicycle and allows the cranks to rotate freely.
It looks like this is worn out or broken. Any bike repair shop will replace it. Shouldn't cost much.
Posted on Jul 18, 2013
  • 2039 Answers
SOURCE: why does my new bike's back wheel not spin easily?
if brake and aligmen t of wheel is good the bearing ajustment is too tight remove the wheel loosen the nut on each side not too loose just so it turn freely with no play in the wheel let me now pierre
Posted on Dec 15, 2008
SOURCE: childs 12 inch mongoose is new, but back wheel does not spin prop
The bikes are pre-assembled by a machine that overtightens the rear axle.  I had the same problem with my daugher's 12 inch huffy princess bike and my other duaghter's 16 inch Schwinn bike.  If you loosen the nuts on the back axle it fixes the problem.  I have read that the idea thing for these bike is to have them re-assembled and re-lubricated by a bike shop, but I thought this might cost as much as I paid for the bike.
Posted on Jun 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: pedals spin wheel doesn't turn
Bottom brackets just connect the cranks to the bike and keep the drivetrain aligned while you wail on the pedals.
I assume you mean the rear wheel spins freely when you pedal after a coast or stop. That would be the pawls in the rear cassette, freewheel or axle failing to engage. When you coast, the whirring, clicking sound you would hear is the pawls gliding over the detents. When you apply forward torque, they drop into the detents and provide drive. Like a ratchet.
Have a shop look at it. Don't ride the bike if it's going to do that. You may stand up and stomp on the pedals and have it let go and wake up with a broken jaw because you went over the handlebars, if you survive being run over. The rear wheel and drive components are not beginner bike mechanics.
You don't say what kind of drive it is.
Posted on Feb 05, 2010
  • 456 Answers
SOURCE: I have a 1998 Huffy 626 12-speed. When i turn the
it sounds like the ratchet mechanism has failed in the freewheel sprocket on the wheel.
Posted on Apr 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: Schwinn Roadster rear wheels won't spin freely
Figure out what, if anything, is rubbing. Maybe the fender(s)?
http://www.schwinnbikes.com/skin/frontend/schwinn/default/pdf/Schwinn-Roadster-Trike-Manaual.pdf
Page 6
Posted on Apr 12, 2011
Trek 7300 effort pedaling
If the wheels spin free then I would look at the bottom bracket. All of the force you use for pedaling relies on the bearings in the bottom bracket being good. Are the pedals hard to turn by hand? Do the pedals themselves spin freely? If the wheels turn, this really only leaves these two rotating points as possible suspects.
Sep 17, 2014 | Trek 7300
Install push rods
Hi Anonymous, assuming yor stock push rods are still in the engine, remove the clip at the top of the outer push rod tube with a screw driver. Lift up the spring cup and squirt some silicone spray or WD-40 on the o-ring, then take needle nose pliers and slide down the inner push rod tube, do this to all of them. Next you can either remove primary cover to access crankshaft extention bolt or jack up rear end to clear wheel, remove spark plugs, and put tranny in high gear to facilitate turning over engine. Rotate engine so that the RE (rear exhaust) push rod is all the way up the remaing three should spin freely. Lift up the bottom of outer pushrod tube, of one that spins, as high as it will go and secure it with a clothes pin. With some bolt cutters break and remove stock push rod. Repeat process for the other 2 that spin freely, then rotate the engine so RE pushrod is at it's lowest point and spins freely then remove it. I don't know what brand your adjustables are so lay them out on your bench, they should be all the same length with the adjusters all the way in. If you have two that are longer these would be exhaust push rods and the two shorter ones will be intake pushrods. Refering to manufacturers instructions you should be able to install new push rods as one piece with adjusters all the way in, or you may have to disassemle and install piece by piece, it happens sometimes. Refer to instructions for complete turns, it's either 3 or 4 usually 4. Since the RE lifter is all the way down as far as it will go on the base circle of the cam start with that one first. WARNING!!!!! before you install any push rod make sure there is an o-ring in the head and one in tappet block. Slide push rod into tube and install, back out the adjuster until it just starts to touch the lifter then with wrenches back out an additional 3 or 4 turns, if you are not sure about the number call the manufacturer. Lock the jam nut and wait a few minutes until the lifter bleeds down and you can spin the push rod freely. WARNING!!!! never attempt to rotate engine unless the push rod you are installing spins freely. OK now lets move onto the next push rod the RI (rear intake) rotate engine so lifter is at it's lowest point on the base circle and install and adjust the push rod, wait for it to spin freely and then do the other 2 in the same manner. When you are finished some push rods will spin freely while others won't depending on cam position this is normal. Now rotae engine slowly 2 or 3 complete revolutions to make sure you have no valve to valve problems or valve to piston problems. If you do re-doo the adjustment on the offending cylinder. When you are comfortable every thing is ok extend inner push rod tube and install clips, replace spark plugs take bike out of gear and repace primary or lower the bike. With fingers crossed and a silent prayer to the Harley Gods fire it up, there may some slight lifter tick in the first minute or two but will eventually stop when you take it for a test ride. When you get back check it for leaks. Thus ends my modified version of War and Peace. Good luck
Apr 19, 2014 | 2009 Harley Davidson FLHX Street Glide
1991 harley ulra classic has stock heads but adjustable pushrods with no colors. how do i adjust before firing motor
Hello
I hope this helps out.
the 2 long push rods are the exhaust and the 2 short ones are the intake.
jack up the bike so the rear tire is off the ground.
put in 5th gear so you can turn over the motor by turning the back tire.
it takes 2 people, one to turn the tire and the other to be looking at the lifter to make sure it is at its lowest point.
you should have all push rods in but very loose.
start with the rear exhaust and then rear intake then front intake then front exhaust.
turn the motor over with back tire, looking at the lifter, watch to see it get to its lowest point.
when it is at its lowest point, stop turning the tire.
now tighten up the push rod so you can spin it but no up and down movement.
now tighten to push rod specs(factory or aftermarket have # of turns or flats to turn)
yours should be 3 turns, but check your manual specs or call dealer and ask how many turns for that year just to make sure.
after 3 turns the push rod will be tight.You have to wait about 15-20 minutes for the lifter to bleed down. try to spin the push rod after 20 minutes. if its hard to spin, wait 20 minutes more, if its hard to spin then you may have over tightened the push rod.
if the push rod spins freely but no up and down movement, then the lifter has bled down and your ready to move to the next push rod.
repeat this process with each push rod.
once done, make sure the spark plugs are out and turn the motor over a few times, as the motor turns over, have your buddy stop when you see a lifter at its lowest point and spin the push rod.
it should spin free with no up and down movement. check them all.
thats it.
just remember to make sure the number of turns for the type of push rods you have.
call the manufacturer who makes your push rods, or call the dealer if they are harley davidsion.
Note: there is basically zero lash once the bike is running, because the oil takes up the clearance.
May 21, 2011 | 2004 Harley Davidson FLHTC - FLHTCI...
Fan not working, outlet is live, product is 6 mos old, located in an indoor swimming pool (endless swim machine) Hi E Dry 100,
If the fan does not operate with the fan switch set "on", there is a problem with the power supply, internal wiring, or the fan itself.
First make sure the dehumidifier is plugged in to a working outlet.
Next unplug the dehumidifier and remove the cabinet cover. Check the internal wiring for loose connections.
Next remove the fan and check that it is able to spin freely (by hand). If it spins freely, it should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
Feb 22, 2011 | Therma-Stor Hi-E Dry 100 Dehumidifier
Pedals spin wheel doesn't turn
Feb 05, 2010 | Cycling
Stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Jan 23, 2010 | Stairmaster Exercise & Fitness
1980 sportster tappet settings
Hydrolic: Set the tappet at its lowest point by rolling the rear wheel with the bike in gear (on a stand of course.) Adjust the push rod until there is no shake. Load the tappet 4 full turns. The push rod will be tight. Wait at least 15 minutes before moving to the next one to allow the pressure to dissapate. Don't want to bend a pushrod or valve. Repeat for all 4 push rods.
Solids: Same as above but push rod should spin freely without any up/down slop. No need to wait for the bleed off. Go right on to the next one.
Jan 31, 2009 | Bike Extreme Lite Youth Shoulder Pad
Girls Huffy 16" bike - back wheel does not spin freely. It tightens up after a few spins.
Try the bearings. Try a different wheel and rim. If its not the wheel then the crank bearings( ones the pedals are on) could be bad or the chain could be not set right.
Dec 24, 2008 | Huffy 16 In. Girls Dora The Explorer...
Why does my new bike's back wheel not spin easily?
Dec 14, 2008 | Mongoose Butterfly Summer 12" Girl's Bike
Cycling Logo
136 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
